Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-20-2008, 12:28 PM   #1
fhslacrosse13
Member#: 65714
Default I think its the motor mounts
Last week I made a trip to the beach and noticed that while driving at a steady speed the car would shutter. The shuttering stops while slowing down and speeding up. My thoughts at first were that it could be the fuel pump but that doesn't make since seeing as it stops when I speed up. It also will shutter while sitting at a stop light. I now think that I might need to replace the motor mounts. Does this sound like the right solution for my problem?
fhslacrosse13 is offline   Reply With Quote
Old 04-21-2008, 07:34 AM   #2
fastwrx25
Member#: 126441
03 bugeye
have you checked the tranny crossmember bolts? mine would loosen everyonce inawhile and would do what you are describing.
jack the car up and see if any bolts are loose in that area...xmember, engine, tranny mounts. etc
fastwrx25 is offline   Reply With Quote
motor taping think its the turbo IAmTheSleepySubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-19-2010 02:13 PM
looking to replace the motor mounts and trans mounts... so Rubber or polyurethane Mechkiller31st Service & Maintenance 2 05-26-2010 02:27 PM
Polished my motor mount, what you guys think ? billy boi Member's Car Gallery 22 09-16-2009 02:45 PM
How do I inspect the motor mounts? leecea Service & Maintenance 3 09-08-2007 12:20 PM
02 Fuel leak. i dont think its the common leak! Robstunner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-21-2007 01:23 AM
