Old 04-20-2008, 12:35 PM   #1
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
Default smoked during smog test (2500 rpm in neutral). Also oil on valve cover breather.
I failed my smog test because of a visible smoke during the 2500 rpm test (for 5 minutes in neutral). It wasn't very thick smoke. It doesn't burn an abmormal amount of oil during normal or hard driving and I haven't seen this smoke before. I also noticed some pretty fresh oil on the passenger valve cover breather near the pcv connection. Can these two be related? Any ideas for a diagnoses? I'll check my pcv system today, but could that allow some oil into the exhaust and cause a little smoke? Any other ideas. Thanks!!!!!!!!!!!!
rex n effect is offline   Reply With Quote
passenger side valve cover breather/oil sep gasket part number bstoehr83 Private 'Wanted' Classifieds 3 04-24-2009 11:55 AM
a lot of oil coming out valve cover breathers.... Jeff54 Normally Aspirated with bolt-on Forced Induction Powertrain 18 07-22-2008 11:21 PM
Some Old Oil on Valve Cover, No Big Deal, Right? Otogi-0049 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-26-2008 04:45 PM
Some thin smoke in neutral. Some oil on valve cover breather. Related? rex n effect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-20-2008 12:38 PM
Catch Can: any problem with tee-ing valve cover breathers and PCV together? yobtah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-03-2004 11:36 AM
