Old 04-20-2008, 01:04 PM   #1
wrxguy02
Member#: 174672
02 AW WRX
02wrxX2,06sti,94wgn,04sti
Default will a 04-05 wrx tranny work on my 02 wrx?
well i blew put my tranny in my 02 wrx and im looking for a new one, ive heard that 04-05 wrx trannys are better/stronger/whatever, but will it fit right up to my 02 or are there "things you have to do"? i really need to know if anyone has done this, i dont really want to here, "yeah a friend of a friend did it and it worked great no problems....", i need first hand experience and/or a subby tech to answer this. dont be offended by the way this is comming off its just that ive got realllllly bad advise before from someone that thought they knew what they were talking about....
if you would pm me with the answer also(that way i dont have to go looking for this in the threads..)
thanks-josh
wrxguy02 is offline   Reply With Quote
Old 04-20-2008, 01:05 PM   #2
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
go for ppgs
ahendrickson is offline   Reply With Quote
Old 04-20-2008, 01:14 PM   #3
jdmimprez
Member#: 153318
08 EVO X GSR
depends.. are you just looking for a replacement or a stronger tranny that'll hold up to more abuse? If you can afford PPG's & plan on putting down 300+ to the wheels or more go w/ a 6-speed swap or stronger gears. If it's a little costly & you're only putting down stock to stage 2... etc #'s then just search for another 5-speed.
jdmimprez is offline   Reply With Quote
Old 04-20-2008, 01:19 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The tranny will work. You will either need to get new axle stubs or convert your box over to accept yours. Stubs is the only difference that will not allow you to bolt it up right away.
will an 04-05 sti clutch work on a 02 2.5rs midnight2.5rs-t Transmission (AT/MT) & Driveline 2 01-26-2007 06:26 PM
will an 04-05 sti grill fit into a 02 wrx? blueandgold Interior & Exterior Modification 3 10-23-2006 10:45 PM
will 04sti struts work on my 02 wrx??? skate enjoi Brakes, Steering & Suspension 4 10-02-2006 09:00 PM
04-05 STI Intercooler setup on a 02 WRX? subaruzero Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-13-2006 07:30 PM
Quick Q&A: Will an 04 rear o2 sensor work on an 02? Blue Rabbit 02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-06-2005 01:20 AM
