Old 04-20-2008, 03:06 PM   #1
myquicksti
Member#: 146902
04 sti
Default So which plug should i use?
So i read all the faq and unabomber stuff "great write up" but still unclear.62,000 miles stg2 accesport forunt mount catless 3" turbo back and recirc aps bov. Fuel pump and short ram 20 psi runs great for what it is .Started little rough idle in the morning just for a second or two and smoothes out. Just started happening this week . Its been on these mods for aprox 20k miles or so and still holds 20 psi when into it an aprox 19 to 20 inches of vacum @ idle. So i figured maybe thrugh a set of plugs @ it. but now due Istick to the stock plug or a step colder.Dont mine spending the money and even if be comes a more freqent thing like having to replace every 10k or 12k. to sacrifice a little more so be it. i would have pm unabomber but i dont have a paypal account. Thks for the help pics comming soon...
myquicksti is offline   Reply With Quote
Old 04-23-2008, 01:31 AM   #2
elusiv
Member#: 170501
PSM TXS Stage Eleventy
Stock spec.
elusiv is offline   Reply With Quote
Old 04-23-2008, 01:57 AM   #3
arch4life
Member#: 172588
2005 saab 9-2x sti
i believe the common rule of thumb is for every 100 hp gain, drop a step colder.
in reality you really wont notice a large change between a step colder plug and a normal plug, all else equal at idle.
do you have any tuning? is the car running proper afr's on boost? these are things to consider as improper afr's can cause lots of issues, one of them being fouled spark plugs.
i wouldnt quickly put the blame on the spark plugs, if that is all you've considered. lots of things can cause a rough idle, perhaps you just need to clean out your Idle air control valve.
arch4life is offline   Reply With Quote
Old 04-23-2008, 01:11 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
stock boost ~15 psi (14.7) for stock plugs
20 psi get the colder plug.
Old 04-23-2008, 09:01 PM   #5
elusiv
Member#: 170501
What does 20psi have to do with anything?
What kind of spark plugs should I use? WRX_MAVERICK Newbies & FAQs 14 04-11-2010 07:42 PM
Which plugs should I use? STIMORRIS Service & Maintenance 4 05-28-2009 02:49 AM
What spark plugs should I use? snowcrzy Service & Maintenance 9 01-01-2007 11:54 PM
What plugs should I use? wrspssshhhh Service & Maintenance 4 10-17-2006 07:03 AM
what spark plugs should I use for over 550+whp on 2.5L WRXINTX Built Motor Discussion 20 08-09-2006 01:45 PM
