Old 04-20-2008, 04:10 PM   #1
Yoshi_STi
Member#: 147827
2004 WRX STi
Post How To JDM Tail light mod 04-05 (WITH PIX)
ok so i was looking on how to do this mod and i searched the forum. i found some how to's but they required rewiring and i found one that didn't but the pictures where all dead... so after i played with my lights for a bit i found out how to do it.
its not that hard and there is no rewiring required.
Step 1. Remove light and harness from the car.
Step 2. Remove the far right light and take out the bulb then move it to the middle light location.
Step 3. take the middle light and move it to far left light.
Step 4. take the light from the far left and move it to the far right.
**NOTE: the harness will be a little tight. its ok**
so here you go hope this helps!
Stock USDM tail lights
Parking lights on no brake
Parking lights with brake
JDM Tail light mod
Parking light no brake
Parking lights on with brake
Yoshi_STi is offline   Reply With Quote
Old 05-15-2008, 10:45 AM   #2
sc00ter
Member#: 117767
2015 WRX
CWP
I figured I would post up the diagram that I used to make it work.
sc00ter is offline   Reply With Quote
Old 05-23-2008, 04:16 AM   #3
Gouki
Member#: 131124
2001 M5
Jet Black
Ups is delivering my tail lights later today. Thanks for the pics!
Gouki is offline   Reply With Quote
Old 05-23-2008, 01:32 PM   #4
jpwulf
Member#: 156950
2012 Optima SX Turbo
wow, what a coincidence, I just did this mod last night...
jpwulf is offline   Reply With Quote
Old 05-27-2008, 01:24 AM   #5
hannibal1
Member#: 164465
04 WRX STI
stg2+intake=292whp,350tq
why you took the bulb out
hannibal1 is offline   Reply With Quote
Old 07-18-2008, 08:59 AM   #6
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
sweet! Im doing this tonight!
skate enjoi is offline   Reply With Quote
Old 07-18-2008, 01:41 PM   #7
dta-wrx
Member#: 118659
2004 WRX
After I discovered this thread about a month ago, I went right outside and did this with a friend. I am very pleased with it.
dta-wrx is offline   Reply With Quote
Old 08-13-2008, 11:25 PM   #8
dub c
Member#: 145069
Keep It Sleazy
wow you went into depth explaining how to switch 3 bulb spots haha.
thanks though! I (and i think we) appreciate the pics and time you spent man!
now im gonna go do mine haha.
dub c is offline   Reply With Quote
Old 08-17-2008, 09:59 PM   #9
N/A_junkie
Member#: 99961
03 Super Obnoxious
Wrx. A rare blue one.
i just did mine...but a little differently...
i just took the bulb out of the #2 slot...and then swapped #1 and #3. this way the circle part will stay on with the parking lights (and nothing else)...but it will brighten as a brake light along with the outside light. doing it this way though...i had to extend the ground wires on both light...but it's not hard at all
anything for a little added light when the brakes are on.
N/A_junkie is offline   Reply With Quote
Old 10-20-2008, 10:17 AM   #10
MickeyD
Member#: 145451
2005 wrx
WFC#185
my number 3 harness doesnt reach the number 1 spot. am i doing this right
MickeyD is offline   Reply With Quote
Old 10-27-2008, 11:35 PM   #11
TMadsen
Member#: 192624
2005 WRX
WR Blue
Is there a way to do this with the 06 STI tail lights?
TMadsen is offline   Reply With Quote
Old 11-23-2008, 02:05 AM   #12
lemons
Member#: 186654
2005 2.5 RS
Navy Blue
Hey I have a quick question. I want to switch it back to stock, but it seems very difficult to remove the harnesses from the slots. 1 of them is easy, but the other too seem like they do not want to come out. Any advice?
lemons is offline   Reply With Quote
Old 11-23-2008, 03:14 PM   #13
06WRXturbo
Member#: 157987
2006 TR Sedan
black
is it #2 that is easy to remove? that was the easiest one to do for me.
do the other 2 turn to unlock at least? I just did this mod a few minutes ago and had your post in mind. Once I did the mod I undid it just to make sure. mine unlocked but didn't want to come out at first. I gently pried at 12, 3, 6, and 9 o'clock and it popped out. I definately noticed while I was changing the plugs that while they are interchangeable, they do not fit perfectly. you are probably just getting the same resistance comming out as they gave you going in. play around with it. be gentle, and walk away for 15 minutes if you start getting pissed off. I tend to break things when i'm frustrated.
06WRXturbo is offline   Reply With Quote
Old 11-23-2008, 07:34 PM   #14
lemons
Member#: 186654
2005 2.5 RS
Navy Blue
I guess ill try that. Thanks. What did you use to pry it out?
Old 12-13-2008, 07:31 PM   #15
OMG AWD
Member#: 177869
2010 2.5 LGT
Graphite Grey Metallic
+1, am i going to need to splice the black wire??
OMG AWD is offline   Reply With Quote
Old 12-20-2008, 04:14 PM   #16
Un0RiGiNaL
Member#: 189748
x2. wont reach
lol @ the thread date
4-20
Un0RiGiNaL is offline   Reply With Quote
Old 01-15-2009, 10:14 AM   #17
full of dents
Member#: 181717
12 sti hatch
w r b
just so i understand completely, there isnt supposed to be a bulb in the middle spot then?
that what it looks like in the pics so i just want to make sure
full of dents is offline   Reply With Quote
Old 01-17-2009, 08:36 PM   #18
Rabid_Machina
Member#: 167278
2004 WRX
is it possible to re-pin the plug on the harness?
if so wouldnt that be easier im sure you can get a tool to do this at radioshack or something if not one of those jewlers screwdrivers.
Rabid_Machina is offline   Reply With Quote
Old 01-18-2009, 09:55 AM   #19
full of dents
Member#: 181717
12 sti hatch
w r b
actually this only took about 30 seconds to do. i dont think it gets any easier then that
Old 01-24-2009, 05:19 PM   #20
jonthesloth
Member#: 184390
1999 Forester
GREEN
i just threw up all over the place
easiest mod to date, did it in like a minute.
epic own
edit: Bump for original post date -_______-
jonthesloth is offline   Reply With Quote
Old 01-25-2009, 08:56 PM   #21
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
just did this. took like 5 minutes. looks great.
AWDshenanigans is offline   Reply With Quote
Old 01-26-2009, 09:19 AM   #22
Blue_WRX
Member#: 192538
sweet write up meng. good job with the pix
Blue_WRX is offline   Reply With Quote
Old 01-31-2009, 08:35 PM   #23
sellers.tony
Member#: 193252
2004 WRX
Platinum Silver Met.
lol i just did this and all my wires reached and everything. took me 10 mins thanks to this write up. props dude.
sellers.tony is offline   Reply With Quote
Old 02-10-2009, 12:14 PM   #24
Astartes
Member#: 183813
2006 WRX TR OBP
WRX STi SGM
Just installed 04-05 tails on my 06 WRX. Unwrapped, snipped, and spliced some of the commons so it would reach easier. It took longer to get the trunk liner up than it did to do this! Looks fantastic, now I just need to debadge tonight.
Astartes is offline   Reply With Quote
Old 02-10-2009, 12:36 PM   #25
OMG AWD
Member#: 177869
2010 2.5 LGT
cant do this shiet with the 06 harness because its too short and i dont want to cut any wires
04 - 05 JDM tail light mod....problems. sc00ter Interior & Exterior Modification 33 07-29-2011 09:40 PM
WTT: 07 tail lights for 04-05 JDM tail lights cojack42o Private 'Wanted' Classifieds 0 01-12-2010 11:02 PM
I need help on 04-05 JDM Tail Light mod JustAnotherSubie Interior & Exterior Modification 14 07-02-2009 06:11 AM
looking to trade 06 sti tail lights for 04/05 lights yoyoman05 Exterior/Styling 4 09-25-2006 10:40 AM
