Old 04-20-2008, 08:28 PM   #1
wanalaugh74
Member#: 148922
2004 Sti
Default Removing 04 Front Bumper
I have search but cannot seem to find instructions on removing the front bumper cover. Is it the same as the 06-07, bc i found a write up on that model. I was wondering if i needed to take off the wheels or if i could use ramps? Thanks for any help.
wanalaugh74 is offline   Reply With Quote
Old 04-20-2008, 09:12 PM   #2
1QCKWGN
Member#: 89021
'08 LGT spec.B
Quartz Silver Metalic
Go to www.IWSTI.com and look in the "how to forums". There is a specific one for 04 bumper removal
1QCKWGN is offline   Reply With Quote
Old 04-22-2008, 10:43 PM   #3
overtheover
Member#: 139547
04 WAGON
[email protected]
^this dude helps alot
its really easy, take off your grill there are a bunch of clips under that..then there 1 clip on each side where the bumper meets your fender in the wheel well area, under the fender liner....
overtheover is offline   Reply With Quote
Old 04-23-2008, 10:23 AM   #4
kyosho
Member#: 53079
2005 RIP 2005 WRX
236/243 CA91 Tim Bailey
you just look under your car and take out all the clips. If you have the plastic undertray, you will need to remove it. Under that plastic tray on each side, there is a push tab that's not as visible as the front ones. You need to take those out. Also, in the fender well on each side of the bumper, there are tabs in there. You need to bend or pull out the fender well to access these tabs. These are tabs are the screwed on type and are a PITA to get out. I had trouble in that i was unscrewing but it wasnt popping up. So i took a screwdriver and just pulled it hard until it came out.
Word of advice: make sure you go to the dealer or wherever and buy some extra push clips. You will probably break a few while you try and yank them out.
Have fun and good luck
kyosho is offline   Reply With Quote
Old 04-23-2008, 03:27 PM   #5
Hypnotk
Member#: 93307
05 WRX
I wouldn't even waste time with the clips that hold the bumper to the fender. The packaging calls them Scrivets. I just use a knife cut it between the fender and the bumper. They are less than a dollar and not worth trying to re-use and a pain to get out.
Hypnotk is offline   Reply With Quote
How to remove an 04 front bumper. shamrock 05 Interior & Exterior Modification 5 07-29-2008 07:14 PM
Wtb: 04 front passenger headlight, 04 front bumper, and 04 hood norexyet Tri-State Area Forum 8 12-03-2004 03:48 PM
removal of front bumper, rear bumper imprezarider31 Interior & Exterior Modification 6 08-22-2003 11:11 PM
Removing the front bumper skin MattJP Brakes, Steering & Suspension 1 02-27-2001 01:53 PM
Removal of Front Bumper STORER General Forum Archive 1 10-31-2000 10:45 AM
