#1 |
Member#: 177979
Vehicle:2001 Impreza RS 2.5 Red |
I stopped at a rest stop for about 5 minutes the other night and when I came back out my headlights/fog lights stopped working. The dash lights come on, the blinkers and the high beams work just fine. I checked the fuses and the relays and they're all fine. The relays aren't switching when I click from hight to low beams so I'm guessing the problem lies somewhere before the relays. Anyone ever hear of a problem like this?
I forgot to mention it's a 2001 RS 2.5
#2 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
I would guess the problem is with the combination light switch. If you didn't check the fuses in the panel under the hood then check them also.
#3 |
Member#: 75234
Vehicle:2004 WRX Wagon with 07 STI 6-Speed Goodness! |
Word.....I'm having the same problem. I was driving home from work and made a pit stop. When I got back in the car, only the high beams worked. I just replaced my low beam bulbs with Silver Stars 3 months ago too.
#4 | |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
If you have your old bulbs and they were good when removed, try those. |
#5 | |
Member#: 75234
#6 |
Member#: 75234
bump for what to check next......
#7 |
Member#: 53443
The problem may be with the DRL relay. Do the daytime running lights work? The info for a '04 WRX shows that a green/red wire ties to the relay from the light switch that should turn on the relay by making a ground connnection. The switching contacts of the relay should then connect a yellow/red wire on the same relay to ground and turn on the low beam lights. The problem may also be within a connection of the yellow red wire near the lights. You should be able to ground the y/r wire manually and turn on the lights if you want to test it.
#8 |
Member#: 75234
Well it's in the dealers hands now.....I hope this might be covered under my Subaru Extra Gold warranty.....I would like to get something for my money....LOL!
#9 |
Member#: 53443
I would think it will be covered unless you did something that caused the trouble.
#10 |
Member#: 47646
Vehicle:0211 RallyWagon DGM Sedan |
#11 |
Member#: 188115
Vehicle:1999 Impreza L Black |
Same problem here. If anyone finds a solution I'd appreciate a tap on the shoulder.
#12 |
Member#: 156883
Vehicle:07 WRX WRB |
i had the same problem in my 240, i retroed an oem hid system in it tho, but i had to rewire my signal wire from the steering column to the ballast bcause the wire was fried. we found out it was fried when he did a conductivity test on the wire if its getting signal? dont know for sure hes the mechanic.
| Thread Tools | |
| Display Modes | |
| Headlights stopped working! | DiscoGsus | Electrical & Lighting | 14 | 04-04-2011 09:44 PM |
| Help! My headlights stopped working | djhowie99 | Electrical & Lighting | 0 | 03-14-2009 02:12 PM |
| Headlights stopped working | Farns801 | Electrical & Lighting | 7 | 12-23-2007 11:47 PM |
| Help - Left headlight stopped working | dmaurzada | Texas Impreza Club Forum -- TXIC | 2 | 01-22-2006 10:25 AM |
| Help - Left headlight stopped working | dmaurzada | Service & Maintenance | 1 | 01-21-2006 07:52 PM |
