Notices
Old 02-20-2002, 07:35 PM   #1
no_rex_yet
Member#: 7351
04 330cic
Default wrx ride quality: 17" vs. 18"
There's an interesting concept being tossed around in the Prodrive spring thread that I though would be nice to bring up: 18" rims ride better than 17" on the wrx!
Simon Lines and others have pointed this out, and from my personal experience, it appears to be true. How is this possible? You would think 17's, being lighter and with thicker sidewalls would ride nicer. However, I've found that my 17" UK oem's ride very harshly. Whereas, when I sat in someone's wrx with 18's and whiteline springs, stock struts, it felt much, much less harsh.
What's up with this?
no_rex_yet is offline   Reply With Quote
Old 02-20-2002, 08:10 PM   #2
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default ride quality
the harness that you're experiencing is actually coming from the entire suspension package (tires, bushings, shock, spring...) having too much uncontrolled compliance.
when a vehicle hits a bump, the suspension (shock and spring) is supposed to absorb the bump/compression. but if bushings & tires are soft and also deform to absorb the bump, you've now added two other "springs" into the suspension equation. here in lies the problem. tires and bushings can act as springs and most often times, are considered undamped springs (relative to dampening levels provided by the shock). therefore, if they are excited by a bump and deflect/deform, they will "bounce" back and continue to resonate. this excitation is felt as a "shudder" in the suspension.
by going from 17 to 18 wheels, what you're inherently doing is increasing the stiffness of one of the "springs" and reducing the chance that it will deform/deflect from a bump, thereby removing one of the undamped "springs" from the suspension equation (nearly eliminating one of the indeterminate frequencies). this removal of excessive tire compliance now forces the shock and spring to deal w/ the bump/compression. by replacing the stock soft bushing w/ a GrpN bushing, you're effectively doing the same thing. now the suspension is forced to work even more to absorb the bump/compression. but, now controlling the suspension's response to the bump is easier since now you know that the shock is nearly the sole controlling factor in the suspension's dynamic behavior.
remember, a suspension system (tires, shock, spring...) is simply an energy dissipation system. energy is inputted into the system via a bump and needs to be dissipated some how. how and where this energy is dissipated determines the dynamic behavior of the suspension package.
duckboy...
duckboy is offline   Reply With Quote
Old 02-21-2002, 09:21 PM   #3
scotto
Member#: 3635
2002 WRX Swagon
Platinum Silver
Nice and logical, a near miracle around here
scotto is offline   Reply With Quote
Old 02-22-2002, 03:34 AM   #4
uwrx
Member#: 3834
WR Blue
Very nice duckboy.
Has anyone with 17" wheels replaced the bushings and seen an improvment?
uwrx is offline   Reply With Quote
Old 02-22-2002, 08:30 AM   #5
Scottie
Member#: 2080
06 Impreza Wagon
Red
I'll have to disagree with duckboy on several points.
This thread started out about a particular 17" wheel and tire combo riding more harshly then a 18" wheel and tire combo. I believe most people judge a particular set-up's harshness by how abrupt given impacts are with road imperfections. I would suspect that most would not consider any oscilation ("resonate") or "bounce" as harshness, but rather as bounciness. Yes, the tires do act as springs, but I would say that generally the stiffer the spring the greater the impact felt in the cockpit (all else bieng equal of course).
Part of the problem with this thread is that it's to generalized. There can be significant differences in all aspects of ride quality, including harshness, of different tires of the same size. Saying you felt a difference between 18" and 17" wheels doesn't mean much to me unless they were the same make and model tire as well as wheel, same section width, same overall diameter, and running at the same inflation pressure.
Inflation pressure plays a significant role in ride quality. If you're running an 225/40/18 versus a 215/45/17 tire, it's likely that you can run a lower pressure in the wider tire.
Now, I'm not ready to throw duckboy's greater tire deflection theory out the window. A totally unsubstantiated theory of mine is this. As your car is traveling along in the horizontal direction, the tires will encounter all forms of road imperfections. Colliding with these imperfections will create a force vector acting in some direction. A component of which will be in the upward (vertical) direction, and another component of which will be in the rearward (horizontal) direction. How much of this impact gets translated into vertical motion will depend on many factors. The shape of the imperfection ( rounded bump, shape limped pothole, gapping crack, etc.) is one. Then there's the tire.
One of the tire's attributes that weighs in on this issue is it's overall diameter. A larger diameter tire will roll up over imperfections more readily. If you have ever used a wheelbarrow with small wheels versus larger wheels, you're likely very fimilar with this phenomenon.
Then there is the tire deformation that duckboy spoke of. A taller sidewall tire (softer tire) may conform to the shape of a road imperfection more than a stiffer shorter sidewall tire, reducing the tranlation of the horizontal force component into vertical motion. Again, I go back to the wheelbarrow analogy. It has been my experience that it will be harder to get a wheelbarrow to hop up, say a inch high step, when the tire pressureis low then when it is high. You have to push harder, in the horizontal direction, to get the wheelbarrow with low tire pressure to hop up onto the step. This means the horizontal force component tends to be higher for softer tires. The springs and struts basically only work in the vertical direction, hence then can only absorb/dampen forces/movement acting in that direction. It's up to the bushing and what not to quell the horizontal component.
I'm just rambling here. It will be interesting to see if others have theories as wacky as mine.
Scottie is offline   Reply With Quote
Old 02-22-2002, 10:23 AM   #6
Simon Lines
Member#: 1540
92 JDM GC8 WRX
2004 2.5 twin scroll 6MT
Hi guys
I would say you both have good points, as has been stated the suspension package on a modern saloon (or wagon) is a very complex thing, the designers have so many ways of influencing the feel.
You can change the type of bush, the stiffness, the way it deforms, the way it interacts with it’s mounting and the way the mounting interacts with the body itself. Then you (obviously) have the springs and dampers, they will have their designated rates but they will also have degrees of compliance too, some designed in, some that just happens to be there. The hub, bearings, CV, axle, brake calliper, brake disc, etc, etc, all have greater or lesser effects. Finally we come to the wheel and tyre, arguably the largest single item in the package.
I would say however, replacing bushes is a one way street to NVH, it starts small, maybe a few roll bar bushes, you think “aaa yea, it’s a bit louder but not much” before you know it you running all polly / ally and the NVH drive’s you up the wall on long trips.
Cheers
Simon
Simon Lines is offline   Reply With Quote
Old 02-22-2002, 04:39 PM   #7
UCI_Scott
Member#: 5088
By now most people reading this know my current set up.
  • STi/SPT everything except
  • ...stock springs and struts.
  • STi top mounts.
  • 18" P1s.
  • High (42psi) tire pressure.
I work on campus at UC Irvine and there is this intersection at Campus Road with a fairly sharp dip. Everyone crawls their cars through this dip. Everyone except me, that is. I simply pretend it's not there.
Passengers cringe and tense up as they notice I am not slowing, but then the soob just soaks up the dip and settles right back down. No undamped wallowing, no jolting out of your seat. Sure, you can feel the dip, but it honestly goes though it better than most cars do at half the speed. Passengers just kind of relax after the dip and don't freak out over any more of my driving quirks.
I've got these nice brand new DMS Golds sitting in my garage for six months but I still haven't felt like installing them.
--scott
P.S. Betfore I did anything to the suspension I had Bridgestone RE730 214/45 R17 on P1s. Later I went to Bridgestone RE730 225/40 R18 on P1s -- still before any suspension work. I don't think you can get much more controlled than that. I will take the 18" any day, zero reservations.
P.P.S. re: NVH: It doesn't seem to bother this 50-year-old, but YMMV.
P.P.P.S. I'm not saying, "Hey! Listen to me! Get 18" wheels!" Get whatever you want. The reason I keep posting is because there are not that many people waving the 18" flag on i-club and I just want my data point logged and I want to offer whatever qualifications I might have for my opinions.
UCI_Scott is offline   Reply With Quote
Old 02-22-2002, 06:34 PM   #8
Simon Lines
Member#: 1540
92 JDM GC8 WRX
It look's like i'm going to be in Irvine over the 2nd or 3rd weekend of March, wil anybody be about?
cheers
Simon
Old 02-22-2002, 06:48 PM   #9
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
If you're there, I'll be there
WagonMonster is offline   Reply With Quote
Old 02-22-2002, 07:17 PM   #10
duckboy
Member#: 6243
2004 XT
hi-yo silver
simon
what's your reason for visiting irvine? are you going to talk w/ Eibach to get a suspension built and cure my suspension problems?
i'd come down to drop by if you're going to be in town.
duckboy (jud)
Old 02-22-2002, 09:14 PM   #11
UCI_Scott
Member#: 5088
Sure! Post here, we'll track you down.
Let's see now... Goat Hill Tavern, 132 beers on tap... Hmmmm...
--scott
Old 02-23-2002, 05:24 AM   #12
scotto
Member#: 3635
2002 WRX Swagon
Platinum Silver
Simon,
Yep, just let us know more when you do.
UCI-Scott,
I thought I rembered you having the DMS 40's... I have heard great things about those.. again lately. Now I don't feel so bad having some odds and ends sitting around waiting to be installed
Old 02-23-2002, 11:34 AM   #13
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Perhaps we need to arrange a SCIC meet in Irvine for 3/9 or 3/16....
Zahnster is offline   Reply With Quote
Old 02-27-2002, 04:37 PM   #14
tifosi77
Guest
Member#: 14110
2002 2002 WRX
Swirly Black
Why don't you guys come karting with us at Dromo ! that evening after you guys meet during the day, Jus a suggestion since Dromo 1 is probably 10-15 minutes from Irvine. Simon YOu are welcome to come as well if any of you are interested (including Simon) email me at [email protected] or you can post on our thread in the Southern California Forum under SCIC Karting Day march 9th
tifosi77 is offline   Reply With Quote
06 WRX Wheels 17" vs 18" wheels aboothman Tire & Wheel 11 11-21-2006 12:16 AM
16" vs 17" vs 18" wheels with the same Max Performance tires comparisons? Heather Tire & Wheel 67 07-03-2003 04:33 PM
17" vs 18" TallguY Brakes, Steering & Suspension 1 04-11-2002 05:55 PM
technical 17" vs. 18" for track lukerussell Brakes, Steering & Suspension 14 01-31-2002 10:24 AM
Basic 17" vs. 18" wheel question MarkZ Newbies & FAQs 10 12-14-2001 04:13 PM
