Old 02-20-2002, 07:38 PM   #1
9
Member#: 4074
1998 Impreza RS
RBP (one of the first!)
Exclamation cam sprocket removal help
ok so i have a problem getting the driverside cam sprockets off. i cant grasp the bolt pattern thats cast onto the sprocket with and tool that i have because the sprocket is kind of concave. so if anyone has any experience or knows of a special tool to use, pllease let me know. thanks in advance.
Courtney
9 is offline   Reply With Quote
Old 02-20-2002, 09:37 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Here's what's used on the 2.5L SOHC camshaft sprockets:
Jon [in CT] is offline   Reply With Quote
Old 02-21-2002, 12:01 AM   #3
9
Member#: 4074
1998 Impreza RS
wow, thanks! but i actually just got it off about an hour ago. all i used was an 8mm socket stuck in between the two sprockets. it caused just enough resistance when they two sprockets started to turn into each other to let me loosen the bolt, then just put it in the other side and you can do the other one, but just enough to loosen them. special tool my a@@!
Courtney
Cam gear removal help Thug Nasty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-13-2008 03:02 PM
How much Jun Cam sprockets can help joekerk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-08-2008 01:21 PM
cam sprocket removal investigation Gator GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-12-2006 11:29 PM
cam sprocket removal White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-03-2005 02:58 AM
Cam sprockets hard to remove? dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-15-2003 01:41 PM
