Old 04-21-2008, 01:38 AM   #1
Kaldar142
Member#: 151090
S197 boosted V8 FTW
Default 5x100 vs 5x114.3
im debating as to whether or not i want to switch to 5x114.3 as it allows for more wheel choices and ive heard the wheel bearing design is alot better...
what do you all think?
Kaldar142 is offline   Reply With Quote
Old 04-21-2008, 03:15 AM   #2
grippy monkey
Member#: 131067
your "stance"
sucks
the fitments for 5x100 are getting better and better
grippy monkey is offline   Reply With Quote
Old 04-21-2008, 09:13 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
if you got $1500 to spend just to have a 'better' wheel selection, go for it.
Old 04-21-2008, 09:37 AM   #4
stiplayer
Member#: 173727
2004 Sti Stage II
^^^ +1
stiplayer is offline   Reply With Quote
Old 04-21-2008, 09:45 AM   #5
JuggernautTCW
Member#: 169223
not worth it since the pre-08s cant really take WIDE rims anyway... so why bother. save the $$ and get the 09 STI.
JuggernautTCW is offline   Reply With Quote
Old 04-21-2008, 07:37 PM   #6
HALFSTI
Member#: 152639
2006 STI
aspen white
Your options arent as good with 5-114.3 (if you are running four pots or brembos) because of very high offset.
HALFSTI is offline   Reply With Quote
Old 04-21-2008, 07:47 PM   #7
boosteddx
Member#: 129504
2004 impreza
stage 2 OS-Tuning
its fun sharing rims with the vw and corolla and tc
boosteddx is offline   Reply With Quote
Old 04-21-2008, 07:57 PM   #8
SpeedElement
Member#: 18920
2004 WRX/STI
We've sold quite a few sets of 18x9 +29 to pre-08 STI owners.
Whats your idea of "wide"?
SpeedElement is offline   Reply With Quote
Old 04-22-2008, 01:27 AM   #9
misterwaterfallin
Member#: 101091
I pieced together mine for a lot cheaper than that
Hubs: $400
Used 06 rotors: $50
6gun adapter: $80
I bought new coilovers but you can get stock strut/springs for like $200
05+ STi bbs's: 450 with tires
Selling all my old stuff
Just the 04 bbs rims: $750
all 4 hubs: $300
Gave the spring/struts away but you can get $250 easy for them if there not blown
It didnt cost too much, and the benefits greatly outweigh the work it takes to get it all together
misterwaterfallin is offline   Reply With Quote
Old 04-22-2008, 02:50 AM   #10
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
ppl have been putting 18x10's on the pre-08 STi's, where have u been?
ommmjido is offline   Reply With Quote
Old 04-22-2008, 02:52 AM   #11
ommmjido
Member#: 35746
08 White GRB
Hubs: $400
Used 06 rotors: $50
6gun adapter: $80
all 4 hubs: $300
its alot cheaper if u already have a STi. for us WRX owners we have to worry abt brakes, rear end/axles etc......
Old 04-22-2008, 10:13 AM   #12
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
yeah, if you wanta ghey hatch (/flamesuit)
+29???
STFU STi is offline   Reply With Quote
Old 04-22-2008, 11:34 AM   #13
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
That's only 1" further out than 8.5 ET48's. A rolled/pulled sedan has a lot of fender space and adding in a small amount of camber takes care of the rest if it's needed.
bluescoobywagon is offline   Reply With Quote
Old 04-22-2008, 11:39 AM   #14
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
x9 +43 with 1/4" spacer is pretty much the upper limit... (at least for a 245/40)
Old 04-22-2008, 12:32 PM   #15
jamesohoh7
Member#: 39070
GTF off my lawn!
Usually, people do the 05 upgrade for the better bearings/hubs b/c they track or autox a lot and are tired of pad knockback, correct?
If that's the goal, then it makes $$-sense to just upgrade vs. buying a whole STi just to cure pad knockback.
If you -just- want 5x114.3's, have your stock hubs redrilled for -way- less $$.
jamesohoh7 is offline   Reply With Quote
Old 04-22-2008, 01:51 PM   #16
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Wow, the amount of misinformation in this tread is amazing!
First:
WRXs need R180s (or R160s with custom hybrid axles: wrx inside and STi outer CV and axle stud) to run the rear STi 5x114.3 knuckles and hubs.
Second:
Please search for 6Gun or posts by javid in the suspension forums. I have posted tons of info, parts, reasons, ect.
I need to write a FAQ....
javid is offline   Reply With Quote
5x100 vs 5x114.3 Molotov Newbies & FAQs 30 05-05-2010 10:25 PM
Hub adapter 5x100 to 5x114.3 chucktoo Tire & Wheel 16 11-30-2009 04:51 PM
Convert 5x100 to 5x114.3 P.C.D. chucktoo Brakes, Steering & Suspension 2 11-13-2005 09:48 PM
5x100 to 5x114.3 conversion Fitz Brakes, Steering & Suspension 2 06-25-2005 12:09 PM
Can we convert 5x100 to 5x114.3? awdlifestyles Subaru Conversions 1 04-01-2005 08:02 PM
