Old 04-21-2008, 02:15 AM   #1
turbo_h4
Member#: 112433
06 WRX.stage2
Default Parking light bulb blinking
I replaced my stock parking light bulbs with the 194 LED bulbs. I noticed my driver side bulb flashing when I turn on the lights. The passenger side is on and solid. Does anyone know what's wrong with this? unfortunately i'm not sure if it was blinking when I first installed it. Also, i tried wiggling the wire around to see if it's a connection problem but doesn't seem like it. and i don't know where i threw the stockers so i can't test using them..
turbo_h4 is offline   Reply With Quote
Old 05-17-2008, 05:37 PM   #2
cynicroute
Member#: 180277
Polarity issue?
cynicroute is offline   Reply With Quote
Old 05-19-2008, 01:03 AM   #3
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Polarity, probably not.
The bulb has a bad circuit board/resistor/diode/whatever.
Return it for a new one.
I had a high-output dome light buzz, then blink, then burn out in a matter of 5-minutes after install & test.
I just opened a package today that I purchased a few months ago and the bulb does not work. Defective "out of the box".
I had another for one of my plate lights, after a month or so, begin to blink and then one by one, each of the SMT's began to go out until one was left doing it's job of producing light w/o incident.
These are mass produced products that are, in the scope of things, still a new product to the marketplace, and there will be defective items now and again.
Find out what the vendor's policy is and go from there.
Good luck.
Old 05-19-2008, 02:45 AM   #4
Handsdown
Member#: 29355
not polarity, polarity means it won't work no matter what. the led itself could be damaged, it's not necessarily the electronics surrounding it. but yeah, it's probably just a bad product.
Handsdown is offline   Reply With Quote
2002 WRX parking light bulbs? Jasno999 Interior & Exterior Modification 25 10-07-2012 08:43 AM
Parking Lights continuously blinking?? darroj Electrical & Lighting 2 02-25-2007 03:47 PM
quick question about buying new turn signal bulbs/ parking light bulbs SoareS Newbies & FAQs 1 10-08-2005 08:43 PM
How do you change the WRX parking light bulbs? YeeHa Interior & Exterior Modification 5 02-03-2002 06:06 AM
danger of high wattage? or What parking light bulb? technix Interior & Exterior Modification 2 09-27-2001 12:38 PM
