#1 |
Member#: 102922
TXIC
Vehicle:2002 WRX Wagon MBP |
I just did a change of fluid for my power steering. Now my wheel is harder to turn sometimes and it vibrates and the power steering pump makes a noise. I used the recommended ATF fluid. I searched and followed the few guidelines of turning the wheel lock to lock about ten times or trying to drive around in figure eights. Neither worked even though I tried them both a few times.
So what should I do?
#2 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
leave it overnight for the bubbles to settle and then go through the bleed sequence again - do the lock to lock a few times with the engine OFF first so any air in there doesn't just get whisked up again by the pump
#3 | |
Member#: 102922
TXIC
| Thread Tools | |
| Display Modes | |
| Fix for air in Power Steering | MasterKwan | Brakes, Steering & Suspension | 2 | 04-04-2009 09:52 AM |
| air in my power steering lines? | IllNastyImpreza | Service & Maintenance | 5 | 05-08-2008 09:30 AM |
| air in power steering | iamadam1122 | Brakes, Steering & Suspension | 7 | 01-15-2008 04:09 PM |
| Power Steering Lines always in the way | GinoEJ253two | Normally Aspirated with bolt-on Forced Induction Powertrain | 22 | 01-12-2004 06:55 PM |
