Old 04-21-2008, 08:16 PM   #1
Farns801
Member#: 155124
2002 WRX VF34!
Platinum Silver Metallic
Default Misfire on cylinders 2 and 3 after reflash
I know this has probably been posted before, but I couldnt find exactly what I needed to know. But here it goes. I installed sti pink 565 injectors 2 weeks ago...no misfire, yesterday I installed my vf34 turbo and reflashed using the 91 vf34 cobb map. I drove for a minute or so and I got 2 cel codes 302 303. I just would like to know if anyone has had this problem and if so, how do I fix it. Mods include: Down pipe, Up pipe, cat back, 565 injectors, vf34, sti tmic with a v1 accesport using 91 octain vf34 basemap and realtime map.
Thank you
Chris
Farns801 is offline   Reply With Quote
Old 04-21-2008, 09:57 PM   #2
Rapp144
Member#: 39806
2003 WRX
BLK
Interesting. You ran what map for the pinks only???
Ok, it is not the map. IMO. You may need to go back thru and check the coil packs and the spark plugs.
A lot of stuff got touched during the install and I bet it is related to the install. So take your time and retrace your steps.
Rapp144 is offline   Reply With Quote
Old 04-21-2008, 10:09 PM   #3
Farns801
Member#: 155124
2002 WRX VF34!
Will do. I just replaced a few minutes ago all the injector seals to ensure that they are sealed correctly. I will be doing a test drive shortly.
Misfire On Cylinders 2 and 4, Help Please! wrx0001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-20-2010 10:29 PM
Misfires in cylinders 1 and 3 when hot. WagonTrailin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-12-2009 06:39 PM
Misfire on cylinder 2 & 4 dumbkid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-29-2006 10:16 AM
cylinder 2 and 3 misfire prometheum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-26-2006 02:07 AM
CEL-misfire on Cyl 1 and 3 wwiifanatic Service & Maintenance 8 02-14-2006 06:12 PM
