Old 04-21-2008, 08:36 PM   #1
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
Default 30k service - that can't be it really?
My car just turned 30k. Due to free oil changes by the dealer, I've been going to the dealer for each service interval.
Now I'm at 30k. According to my.subaru.com, the 30k service is this, (if I filter out the word "inspect):
- oil change (free)
- replace coolant
- replace air filter (stupid.. this is a 2 minute DIY)
- replace brake fluid (I do track days, so I've done this already several times)
Is that it? How about tranny fluid? Any other adjustments?
That doesn't seem worth it to pay the dealer to do it.
At the same time, I don't know if there are "hidden" things that make a periodic visit to the dealer worth it. For example, on my wife (non Subie) car, I took it in for the long interval service and found there was a service bulletin on the brake master cylindar... and it was replaced for free under warranty.
Any known TSB's on 06 wrx wagons?
chimchimm5 is offline   Reply With Quote
Old 04-21-2008, 08:44 PM   #2
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
Ok... my dealer also does tranny fluid and rear diff fluid...
And "inspect and tighten" all under carriage, etc. (fo real?)
all for a measely $420 (!!!). I know that's going rate for cars, but sheesh, no wonder we DIY.
Old 04-21-2008, 09:35 PM   #3
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
my.subaru.com is WRONG.....read the Maintenance FAQ stickied at the top of this forum for what you should be doing.
Old 04-21-2008, 10:11 PM   #4
OMG AWD
Member#: 177869
2010 2.5LGT Stage 2
Graphite Grey Metallic
oil changes are free under the warranty???
OMG AWD is offline   Reply With Quote
Old 04-21-2008, 11:26 PM   #5
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
No... it was a deal my specific dealer gave for buying from them.
Old 04-21-2008, 11:41 PM   #6
OMG AWD
Member#: 177869
2010 2.5LGT Stage 2
ohhh ok darn! haha
Old 04-22-2008, 07:57 AM   #7
__raj
Member#: 177241
2005 LGT Wagon 5mt
Unabomber thanks for FAQ but link was not entirely direct.
I found the following http://www.subaru.com/owners/schedul...sp?from=topNav
__raj is offline   Reply With Quote
Old 04-22-2008, 11:06 AM   #8
leecea
Member#: 37359
2003 WRX
According to the FSM, it looks like you are doing the right things, though they do add an advised replacement of the fuel filter too on my model year.
There is no change interval specified for tranny and diff, but many people do it anyway.
There are a lot of "inspects".
leecea is offline   Reply With Quote
Old 04-23-2008, 10:49 PM   #9
awdguy
Member#: 59101
2004 wrx
white
Do all the fluid change yourself. Save a little money. you'll be happy that you did
awdguy is offline   Reply With Quote
Old 04-23-2008, 11:50 PM   #10
Roamrex
Member#: 171487
06 WRX Wagon
SGM
I just did mine in span of two days at 30k.
Replaced engine coolant (used Subaru brand with bottle of conditioner)
Replaced brake fluid
Replaced Manual transmission fluid
Replaced Rear differential fluid
The power steering fluid is not needed but I replaced it as well
Roamrex is offline   Reply With Quote
Old 04-25-2008, 07:05 PM   #11
Gunner
Member#: 36540
04 Silver GGA
Cobb Stage 1 EQ Tuned
Does clutch fluid needs replacement at all? I am close to 60k...
Gunner is offline   Reply With Quote
Grinding noise - that can't be good 98LegacyGT Transmission (AT/MT) & Driveline 5 11-21-2005 11:52 AM
Are there wrongs that can't be forgiven? DrDRum Off-Topic 58 06-30-2005 09:51 AM
How do you delete a file that can't be deleted??? xfactor834 Off-Topic 27 01-05-2004 04:40 PM
Songs that can't be played loud enough MattSEG Off-Topic 60 05-25-2003 11:11 AM
a thread topic that can't be deleted, puppies -LD Off-Topic 20 02-18-2003 10:44 PM
Message Board Statistics All times are GMT -4. The time now is 05:52 PM.
