Old 04-22-2008, 12:14 AM   #1
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
Default How To: Fogs/Driving Lights With High Beams
hey guys, im back with another little write up!
This write up is to help anyone that thinks their driving lights are too bright, and need to be switched on and off with their highbeams.
This wiring diagram illustrates how to set up any aux lights to be:
OFF with lows
ON with highs
ON with parking lights
All the above using the factory foglight switch. (and no extra wiring through the firewall)
The 9007 application is for 2002/2003 iirc. Any other years can use the lowbeam switched ground from whatever type of connector your MY has
jdubya301 is offline   Reply With Quote
Old 04-22-2008, 01:21 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Keep in mind that what you just did ONLY will work with an 02-03. Subaru changed the way the headlight wiring works every time they changed the headlight shape.
This won't work for an 04+ at all.
Old 04-22-2008, 01:36 AM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
thanks for the heads up..
what are the major differences between 02/03 and 04/05s (besides the split high low beam bulbs)
Old 04-22-2008, 03:02 PM   #4
Handsdown
Member#: 29355
those are great vectored renditions of ff1000's! i just wired mine up independantly. i had it on highs once but i had to change it once my wiring harness got screwed up.
Handsdown is offline   Reply With Quote
Old 04-22-2008, 06:13 PM   #5
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
haha thanks handsdown
i feel like i spent too much time on them (probably a good 25 mins)
let me tell you, it was definitely a relief to figure out this wiring. i hated having to hold my hand on the fog switch while driving these windy PA back roads.
if you have some time i would suggest trying to do this set up. its awesome.
o yeah ff1000s ftw.
Old 03-17-2010, 07:13 AM   #6
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
The 9007 plug, which way are you looking? or, which ground are you showing, high or low? I take it low.
Also, doesn't the factory foglight switch only get power when the low beams are on? and kills the foglight relay when the highbeams are on?
indytruckboy is offline   Reply With Quote
fog light with high beams Spy Electrical & Lighting 1 12-04-2004 10:51 PM
Fog Light with High Beam mod documented! 8Complex General Forum Archive 13 03-19-2001 03:23 PM
FYI: Driving lights with high beams legal in PA Jon Bogert Mid Atlantic Impreza Club -- MAIC 1 06-27-2000 10:37 AM
i did MY00 RS fog light with High beam mod joostin420 Technical Forum Archive 8 06-20-2000 04:53 AM
Fog Lights with High Beams is Legal daytonians Technical Forum Archive 17 06-17-2000 04:37 AM
