Old 04-22-2008, 03:42 AM   #1
jt0thevizzle
Member#: 174979
Default HID not lighting up at times!!?!
I finally installed my HID lights and sometimes only 1 bulb would come on at a time when i'm on DRL so i would turn on my lights on and off until both of them came on at the same time... does anyone know why this is happening or how i can fix this? I seem to have a lot of problem with HID lights
jt0thevizzle is offline   Reply With Quote
Old 04-22-2008, 03:54 AM   #2
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
Try disabling your DRL first. Then try swap the working side ballast to the faulty side ballast. See if the problem persists.
Spore is offline   Reply With Quote
Old 04-22-2008, 09:36 AM   #3
viaburn26
Member#: 167272
2004 STi
from what i have heard it takes 13.1 volts to turn on each one so there may not be enough voltage during startup or when ever your drl's are activated . i guess try turning on the headlights then off by the switch to see if if would fix the problem . thank god mine didn't come with drl's lol .
viaburn26 is offline   Reply With Quote
Old 04-22-2008, 11:19 AM   #4
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
I believe DRL doesn't supply a constant voltage, but more of a sinusoidal wave. The reason behind it is to prolong the bulb's life. The sinusoidal voltage wave can't be detected by the naked eye with halogen bulbs. But since HID requires a constant voltage, the voltage wave will cause the HID to turn on and off. The only way to solve the problem is to feed the HID with either 0v or full 12v.
Old 04-22-2008, 11:54 AM   #5
hornyturbo
Member#: 108618
2010 10 RX350, 04 A4
12 IS350, 08 STI
disable the DRL
hornyturbo is offline   Reply With Quote
Old 04-22-2008, 09:27 PM   #6
jt0thevizzle
Member#: 174979
ok thanks guys haha now i gotta find a thread on how to disable them. THanks tho
Old 04-24-2008, 01:43 AM   #7
jt0thevizzle
Member#: 174979
Ok wait how does disabling the DRL help the HID both come on? keep in mind that my lights do'nt flicker... 1 just turns on and the other one don't... 2 are rarely off at the same time.
Old 04-25-2008, 04:51 PM   #8
jt0thevizzle
Member#: 174979
ohhh hailll yeahhh hahaha i jsut disconnected my DRL and so far it is working when i turn on my headlight lets hop eit keeps working haha thanks again guys !!!
Old 04-27-2008, 10:41 AM   #9
zondotca
Member#: 154982
2006 WRX Wagon
Had the same problem after DRL disable. Definitely due to low voltage during starter cranking. I just got in the habit of turning the lights off when parking and turning them on after the car was started.
zondotca is offline   Reply With Quote
Sick NEW HIDs. To light UP your life and the Curves Aheard!!! tunerzimage Exterior/Styling 14 01-11-2009 09:02 PM
Help! Side markers and Parking lights not lighting up...? stevey323 Electrical & Lighting 1 03-25-2008 02:04 PM
Cruise control button not lighting up... AK*WRX*2004 Electrical & Lighting 5 01-17-2006 01:55 AM
needle not lighting up? suby ej25 Tri-State Area Forum 6 02-21-2004 09:51 AM
cobalt gauges not lighting up nvrenuf Electrical & Lighting 3 04-05-2003 11:35 PM
