Old 04-22-2008, 06:24 PM   #1
ANT03IMPREZA
Member#: 137134
03 Wrx
Platnium Metallic Silver
Default Rear wrx brake swap. PLEASE HELP!!!!
just like the title says, im am purchasing a 06 oem 4 pot 2 pot setup and i know the front will bolt on with the bigger rotors, but what about the back... ive been told they bolt right on, and ive also been told they need a rear brake kit, if any one knows for sure please let me know ....
thanx in advance
ANT03IMPREZA is offline   Reply With Quote
Old 04-22-2008, 06:27 PM   #2
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
you need a bracket and also a bigger rotor, the 06+ wrx's came with 4 pots front calipers and the same size rotors as in past years but the rear rotors are bigger and the 2 pot caliper will not bolt up without a bracket. so in short if you have just the calipers for the front you can use your stock front rotors; and for the rear you will need 06+wrx rear rotors(i happen to have a set for sale) AND rear caliper brackets, Kartboy makes some. hope that helps
ray101381 is offline   Reply With Quote
Old 04-22-2008, 06:33 PM   #3
ANT03IMPREZA
Member#: 137134
03 Wrx
thanx..how much does that bracket usally run for...... so for the fron t i can use my stock rotors...what about lines
Old 04-22-2008, 06:38 PM   #4
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
for the front you can use the front rotors and lines, i would get the rotors turned before i reinstalled them and flush all the brake fluid and bleed with new fluid for the whole system. for rears, i think the lines can be reused but definitely not the rotor. the bracket is 225 through Tom @ kartboy. they make very very high quality stuff and if anything goes wrong Tom's got your back.
Old 04-22-2008, 06:40 PM   #5
ANT03IMPREZA
Member#: 137134
03 Wrx
thanx bro
Old 04-23-2008, 04:47 PM   #6
ANT03IMPREZA
Member#: 137134
03 Wrx
ok so everyone agrees..i can just swap the fronts over and for the backs ALL i need is the kartboy bracket and a bigger rotor???correct
Old 04-23-2008, 05:45 PM   #7
jamal
Member#: 71875
98 Legacy GT
my wheels fit
correct.
These brackets: http://www.fastwrx.com/retwcaad.html
06-07 wrx or 05+ LGT rear rotors.
jamal is offline   Reply With Quote
Old 04-23-2008, 08:51 PM   #8
ANT03IMPREZA
Member#: 137134
03 Wrx
cool thanx bro so bigger rotors and these brackets and im set
Front WRX brake swap done! - now the rear... (E-Brake Question) Type2 Brakes, Steering & Suspension 0 10-05-2009 09:56 AM
Im a little confused and need some help with my brembo swap..please help? Turbo_Twinky Brakes, Steering & Suspension 16 08-18-2009 11:21 AM
Car is running lean after JDM WRX swap, please help!! wrxfactor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-14-2006 08:48 PM
rear disc brake swap - gurus please advise Migo Brakes, Steering & Suspension 6 10-18-2005 08:35 PM
Wrx Brake Swap, what to do with the Rear? DDMan Brakes, Steering & Suspension 5 07-03-2003 01:02 AM
