Old 04-22-2008, 09:14 PM   #1
thebasicnecessities
Member#: 153611
Default few questions about motor build up.
so i have an sti bottom end and am thinking of using mahle 100mm pistons, eagle rods or pauter rods, cosworth rod and main bearings, cometic head gaskets and arp head studs. i also have the 2.0 heads and was considering using JUN 264 cams.
to get to the point, i was wondering if i am heading in the right direction and how much it would cost (roughly) to get my engine ported and balanced with all the listed goodies installed. is there anything else i need? has anyone else done a similar build up?
other current mods include a gt35r, 800cc injectors, perrin fuel rails, txs fmic with custom piping and reversed intake manifold, tgv deletes, full catless exhaust with gt spec equal length headers and i think thats about all that matters.
Please HELP. thanks!
thebasicnecessities is offline   Reply With Quote
Old 04-24-2008, 11:13 PM   #2
thebasicnecessities
Member#: 153611
... anyone?
Old 04-25-2008, 05:02 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
you want to look into different pistons.
but use ej255/57 head gasket. the rest of your build
sounds good. read up on oil pumps.
A few questions about my JDM V7 207 build. 02WRXNY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-28-2008 04:39 PM
A few questions about my build??? shouldaboughtanSTI Built Motor Discussion 9 07-11-2006 09:53 PM
99RS 2.5L stock motor build up questions. chrismindless Normally Aspirated Powertrain 3 04-21-2005 03:27 PM
wrx motor build up questions azn2yunr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-04-2005 04:39 PM
Questions on ej25 motor build up SCOOBYLOVER Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-05-2002 01:37 PM
