Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Old 04-23-2008, 01:07 AM   #1
viaburn26
Member#: 167272
2004 STi
Default Grinding Noise at Idle on a 04 STi !
When I'm at idle there is a grinding noise with the clutch out " not touching the pedal " but as soon as I depress the pedal it goes away . Let off the pedal it comes back . I recently just had the clutch changed out to a act hd with streetlite flywheel . Now before you say thats the problem , I have had the same Exact problem before the clutch job . I had the dealer to the clutch job with the timing belt 105K service . Had the dealer give me all the parts that came off the car back from the clutch job . The only thing they didn't put in the box was the Throw Out Bearing . Yes my new clutch kit came with a new throw out bearing , so now i'm thinking they didn't even change it . The dealer said they did change it since the stock bearing won't fit on the act clutch " smells like bs " .
what do yall think ?
viaburn26 is offline   Reply With Quote
Old 04-23-2008, 03:12 AM   #2
rendog24
Member#: 125463
how far do you have to disengage (push the clutch in) for the noise to dissappear? if when you barely touch it, i mean barely move it a 1/4 inch or something and the noise goes away, i would give a pretty good guess it is the throwout bearing. i had the same problem on my wrx, but mine sounded more of a squeal , like a belt was a little loose. they prolly didnt change the TO bearing, they tellyou what you wanna hear, those stealerships...
rendog24 is offline   Reply With Quote
Old 04-23-2008, 03:34 AM   #3
viaburn26
Member#: 167272
2004 STi
i know its not a belt , the noise has been seen by two other subaru mechanics both saying its the throw out bearing . why would they remove the old throw out bearing from the old pressure plate if they were supplied with the new clutch and throw out bearing ? from what i have researched when you unbolt the pressure plate the throw out bearing stays on it . does anyone have a pic of the act throw out bearing vs a stock one ? and is there anyway to see the throw out bearing with out removing the trans ?
Clutch/gear grinding noise at idle? rhinotech Transmission (AT/MT) & Driveline 0 12-13-2007 04:27 PM
RPM's up and down at idle on 04 wrx.... snobrder_ad Factory 2.0L Turbo Powertrain 8 03-03-2007 12:40 PM
Squeeking noise at idle on my 06 WRX??? ChrisCJ99 Factory 2.5L Turbo Powertrain 3 12-29-2006 12:37 AM
Grinding noise at 4-5k Hiroki Tada Legacy Forum 9 08-25-2005 12:52 PM
What's vacuum say on the boost guage at idle on STI? SupersayianNeo Newbies & FAQs 3 06-17-2004 10:04 PM
