Old 04-23-2008, 03:44 AM   #1
pheonix991
Member#: 154173
2006 STI
Default How do I get the crank pulley off w/ motor out of car?(I've searched)
I have my motor out of my car, and I need the crank pulley off. What is the best way of taking it off? I tried the screwdriver in the torque converter wheel, but, that didn't work, just bent the screw driver really bad. Should I get an impact gun? I'm going to call my friend at the subaru dealership to see if he can borrow the tool for me.
In case you were wondering, I'm changing head gaskets.
pheonix991 is offline   Reply With Quote
Old 04-23-2008, 06:46 AM   #2
sjl1614
Member#: 56791
06 OBS
Impact gun or a chain style wrench to hold the crank pulley.
sjl1614 is offline   Reply With Quote
Old 04-23-2008, 06:24 PM   #3
pheonix991
Member#: 154173
2006 STI
Looks like I'll be adding an impact wrench to my toolbox!
Edit: called dealership, he told me to go rent a crank shaft pulley puller from autozone, gunna go pick it up in a little while.
Old 04-23-2008, 06:32 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
I use an impact gun. For the really tough ones, I use a big prybar in the flywheel, and a 2 foot long pipe on a 1/2 drive ratchet.
Old 06-09-2009, 12:49 AM   #5
subieguy87
Member#: 153412
1998 Impreza wrxRS
i was wondering if i could put in 2 bolts in the crank at the FW side and pull with a pry bar countering the use of the socket...
subieguy87 is offline   Reply With Quote
Old 06-09-2009, 04:19 AM   #6
pheonix991
Member#: 154173
2006 STI
Just go to autozone, that puller worked amazing. Used it on two other cars since.
Old 06-09-2009, 12:54 PM   #7
RedefinedTR
Member#: 149848
2011 Honda CRZ
Performance White Pearl
Go to perrin's website. Search for the crank pulley. There are instructions there.
RedefinedTR is offline   Reply With Quote
Old 06-09-2009, 03:17 PM   #8
00LGTP
Member#: 172618
1995 EJ253/D25 GC
371hp/355tq 1.5xtr 93oct
poor mans impact
00LGTP is offline   Reply With Quote
Old 06-10-2009, 10:28 AM   #9
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
best thing ive used is a peice of 1" wide flat steel about 8" long, drilled holes on either side.
one bolt through the steel and the trans bolt hole, and another bolt through the steel to the pressure plate bolt hole on the flywheel.
legacydreamz is offline   Reply With Quote
Crank pulley removal tips - engine out of car. boostinms Normally Aspirated Powertrain 17 04-18-2010 04:40 PM
How do you get the Subie badge off the grille?? Patrick Olsen Legacy Forum 13 04-18-2006 11:11 PM
How do you get the psst sound off the BOV? colombo140 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 10-19-2005 07:32 PM
can't get the crank pulley off! maciek Normally Aspirated Powertrain 2 05-02-2002 08:54 PM
how do I get the warning signs off of the visors???` custom_impreza Interior & Exterior Modification 3 05-17-2001 07:59 AM
