Old 04-23-2008, 08:56 AM   #1
smurfwrx
Member#: 151928
09 Triumph S3
Angry I am SO done with Mobile1
I'm am so tired of checking my oil (do it often - every fill-up or every other fill-up minimum.) and finding I'm nearly a 1/4 - 1/3 qt. low. NO blue smoke, just eating up oil as other's have complained about.
I'm not trying to trash M1 just b/c I've heard a lot of people complain about it but b/c I myself have been using it for almost a year and I'm not happy with it. I've read great things about german castrol 0w30 and my happy ass will be marching down to Autozone with high hopes of finding it today.
Let me just throw this out there, any "low" reading on my dipstick makes me panic and I'd venture to guess that's a better reaction than being all cavalier about it, but how low is low enough to be worried? Consider that it would not have been low for long, seeing as how I check it frequently and top off accordingly. I run WOT at least once a day up in the neighborhood of 6k RPM either on my way to work or on the way home, but otherwise, completely normal highway commute w/ minimal "city" driving.
smurfwrx is offline   Reply With Quote
Old 04-23-2008, 09:32 AM   #2
bluesubie
Member#: 767
04 FXT
Which grade? In a modified bugeye in SC, I would use Mobil1 High Mileage 10W30 year 'round at a minimum. It's a tad thinner at operating temp than GC, but would be a better fit for you if you're running the regular 10 or 5W30. Otherwise, use their best 30 weight; 0W40.
-Dennis
Old 04-23-2008, 09:36 AM   #3
WizardGandoff
Member#: 36667
04 DrgSmugrXps
Blackwiththablingblingold
i heard moble one is for high performance v8s like corvetts whatever. i used castrol for 90000 miles and never had a prob with anything. the first time i switched to mobile one i spun a rod bearing and seized my 2.0 liter motor last june
WizardGandoff is offline   Reply With Quote
Old 04-23-2008, 10:19 AM   #4
smurfwrx
Member#: 151928
09 Triumph S3
^ Yeah, that's what I'm trying to avoid.
I'm stage2 right now running an OTS from Cobb. 93oct. I have further mod plans as well. My car is just eating up M1 10w30 and 5w30.
Just called Autozone. They've got 8qt. of German Castrol 0w30 w/ my name on it. Picking it up at lunch today.
Unless................... someone has other recco's? I've just been steadily hearing great things about this GC.
Old 04-23-2008, 10:28 AM   #5
pweizman
Member#: 131268
.... GOD........
I have an '03 stg. 2 wagon...my car uses a bit of oil too.
About .5-.75 every 3000 miles. I think it is some what normal for a WRX.
I have heard good things about Rotella also...and in general switching to a 5w40 or 10w40.
I think I am going to try Rotella 5w40 next time...
I have tried about every type of 5w30 oil...and my WRX consumes it at the same rate.
Mobil One
Synpower
Durablend
Valvoline high mileage
Castrol GTX
Patrick
pweizman is offline   Reply With Quote
Old 04-23-2008, 12:42 PM   #6
smurfwrx
Member#: 151928
09 Triumph S3
cool. Getting ready to pick up some GC 0w30 now. I'll be sure to get back to eveyone in a couple weeks w/ impressions, differences, whether or not all the freaking oil is still there!!!!!!
Old 04-23-2008, 12:44 PM   #7
sujorosa
Member#: 146739
1999 Camaro z28
Red
just curious if uve all checked ur turbos out.. my buddy has an 04 sti, EATS oil like there is no tomorrow.. finds out the turbo is leaky.
sujorosa is offline   Reply With Quote
Old 04-23-2008, 01:32 PM   #8
pweizman
Member#: 131268
.... GOD........
Changed my turbo 2000 miles ago...still the same usage.
It did fix my slight oil return line leak...but not the oil consumption.
Patrick
Old 04-23-2008, 01:45 PM   #9
sujorosa
Member#: 146739
1999 Camaro z28
Red
yea ive heard from others that Mobil1 disappears in subaru engines on top of the leaky turbo thought. have u looked into amsoil?
Old 04-23-2008, 01:54 PM   #10
jay25RS
Member#: 4273
2011 GR-STI
& 2013 Impreza Sport
Mobil 1 10w-40... fixed much of the consumption issue for me...
FWIW, Mobil 1 5w-30 is thicker than their 10w-30 at temp...
Next oil change going to 15-50... warm weather is here!
jay25RS is offline   Reply With Quote
Old 04-23-2008, 02:12 PM   #11
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
ditto. M1 10w-40 works with very little consumption for me. my motor drinks M1 5w-30. i tried castrol 10w-40 and quaker state 10w-40 synthetics, but it still consumed a little.
dantastic is offline   Reply With Quote
Old 04-23-2008, 02:46 PM   #12
Mykl
Member#: 14311
2010 GTI
I've had two different cars that liked to hide 5w-30 Mobil 1 in mass amounts. My old 2002 Sentra Spec-V, and the STi. On both cars, within 500 miles of an oil change, each found a way to completely hide at least a single quart of oil. I have absolutely no idea where it was going. The car didn't seem to be burning it, and it wasn't leaking. Funny thing was, after that initial loss of oil, the level would stay rock steady until it was time to change the oil again.
I switched to GC 0w-30 in the STi and I slowly use roughly a half to a single quart of oil for a 3000 mile oil change, which is perfectly acceptable.
I will never use Mobil 1 again.
Mykl is offline   Reply With Quote
Old 04-23-2008, 02:51 PM   #13
jays05
Member#: 78165
05 STI 35r + e85
Good luck, my suby consumed every kind of oil I tried until I finally changed over to a real air/oil separator. Including M1 5w30, 10w30, GC 0w30, Royal Purple 5w30, 10w30, 10w40, etc etc... IMO most of the consumption in subarus is because of the pcv system.
jays05 is offline   Reply With Quote
Old 04-23-2008, 06:35 PM   #14
my scoop eats babies
Member#: 174894
Good luck, hope it works for you. I was having issues with my rex consuming M1 as well, I was filling up almost 2 quarts between oil changes. I switched to Amsoil Euro Blend 5w-40 on my last oil change. 3k miles is right around the corner and I had literally 0 consumption last I checked a few days ago.
my scoop eats babies is offline   Reply With Quote
Old 04-23-2008, 06:44 PM   #15
joebush44
Member#: 163483
2003 Bugeye
2.5L Hybrid WRB
Ive also heard Mobile 1 = Oil Consumption.
Royal Purple Here
joebush44 is offline   Reply With Quote
Old 04-23-2008, 08:03 PM   #16
elusiv
Member#: 170501
PSM TXS Stage Eleventy
From my experience, turbo cars hate synthetic oils. I will never use Royal Purple again for as long as I live.
elusiv is offline   Reply With Quote
Old 04-23-2008, 08:44 PM   #17
Redline927
Member#: 77622
Been running Mobile1 10w-30 in my car for a long, long time with NO oil consumption problems whatsoever. I change every 3k.
2.0 wrx with about 300whp.
Redline927 is offline   Reply With Quote
Old 04-23-2008, 09:52 PM   #18
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I don't know about that...
I have found that oil consumption sort of goes with how I am driving - the harder you push, the more that goes away. Mobil 1 (5w30 and 10w30) generally seemed to go away the fastest - Redline 10w30 sticks around longer, as does Royal purple 10w30 and 10w40 - haven't tried much else.
Old 04-24-2008, 09:25 AM   #19
bluesubie
Member#: 767
04 FXT
You folks really need to have a look around at the uoa threads here. I've run 8,000 miles on GC with good results and consumed only 1qt.
Here's a uoa on Redline 10W40 at 6,800 miles with no make-up oil added.
However, use oils like M1 xW30 and RP xw30 in a hard driven turbo and you will likely have consumption. UOA threads don't get a lot of attention here because they have facts. People would rather read threads entitled, "Oh noes, my engine assploded on Mobil1".
-Dennis
Old 04-24-2008, 10:22 AM   #20
shamrock 05
Member#: 120057
2004 "Bugeye"
I cant find redline, so I am going to be using Amsoil 5w-30. I have never heard anything bad about Amsoil, anyone else
shamrock 05 is offline   Reply With Quote
Old 04-24-2008, 11:15 AM   #21
bluesubie
Member#: 767
04 FXT
Old 04-24-2008, 11:48 AM   #22
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
ive run mobil1 5w30 in my sti sense the first oil change and i get no consumption on normal driving, under hard driving i will use very little.
that said i am going to try castrol 5w30 syn in my current motor.
i am also considering going to the castrol 0w30 as my car doesnt drive in teh winter. it shouldnt be a huge issue.
jnorth85 is offline   Reply With Quote
Old 04-24-2008, 11:54 AM   #23
smurfwrx
Member#: 151928
09 Triumph S3
I think I posted earlier in the thread about "how low is too low?"
If you check your oil and notice it's just on the tip of the dipstick (just below low dot) is it a guaranteed problem? Already doomed?
I checked mine and was down ~1/4 - 1/3 qt. yesterday and topped off. Just wondering HOW BAD that is. It couldn't have been low for long. I check it pretty regularly and was surprised to see it that low.
(no leaks, no blue smoke. I checked all that. Just consuming M1)
Old 04-24-2008, 12:10 PM   #24
bluesubie
Member#: 767
04 FXT
Use 0W30. It's thicker at operating temp and cold temps and is a more shear stable oil. The 5W30 N. American Syntec isn't all that spectacular.
-Dennis
Old 04-24-2008, 03:42 PM   #25
BGPKR
Member#: 41842
2006 LGT LTD 5SM
I'm currently using Royal Purple 5w40 and no comsumption.
BGPKR is offline   Reply With Quote
I am done with pulling ahead!! *rant* mr2guru Off-Topic 34 03-27-2006 01:26 PM
Am I finally done with all of the bolt-on's??? Red Rexx Factory 2.0L Turbo Powertrain 47 11-17-2005 11:23 PM
i think i am done with my exterior finally! sti s202 sorta nutzkicker617 Member's Car Gallery 29 07-12-2005 03:22 PM
I think I am all done with Boston women. chrislehr New England Impreza Club Forum -- NESIC 79 10-01-2004 11:27 AM
I am so bored with the internet... Eric SS Off-Topic 17 02-09-2004 05:37 PM
Message Board Statistics All times are GMT -4. The time now is 01:17 AM.
