Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-23-2008, 06:52 PM   #1
joebush44
Member#: 163483
2007 STi
Default A/C Compressor Q
Hey all, quick question. Is an AC compressor off an 05 STI the same as the one I have on my 03 WRX? My comp took a crap the other day and im lookin to get a used one. Found a good deal on one from an 05. Is there any difference in compressors from the 2.0 to the 2.5??
Thanks guys
Part #73111FE021 02-03 2.0
Part #73111FE040 04-06 2.0 or 2.5
What gives?
joebush44 is offline   Reply With Quote
Old 04-25-2008, 10:35 PM   #2
joebush44
Member#: 163483
2007 STi
Nobody knows if the 2.5 ac compressor is the same as the 2.0?
Old 04-26-2008, 12:21 AM   #3
kaos200
Member#: 2692
The 05' has what they call a "thermal protector" in it. The single wire that your 03' has (the blue one) does the same thing as the blue wire on the 05' compressor (which has blue, yellow, and green/orange wires). But your A/C system does not have the wiring in place to make use of that thermal protector in it (which just shuts the a/c relay off if the compressor overheats it seems). You COULD wire it in if you'd like, just have to extend two wires.
Other than that the only thing I am not positive about is if the fittings are the same for the lines.
kaos200 is offline   Reply With Quote
18g vs 20g compressor housing. Can you put a 20g wheel in a 18g compressor housing? NITROS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-17-2009 07:01 AM
AC compressor clutch / compressor smeghead Private 'Wanted' Classifieds 11 10-01-2007 12:53 PM
WTB - 2002 WRX A/C Compressor / A/C Compressor Clutch wetwilly1169 Private 'Wanted' Classifieds 0 06-16-2007 02:17 PM
18G Compressor Cover vs. SZ49 Compressor Cover keyser_soze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-20-2005 01:11 PM
Increase compressor efficiency for 12 bucks - no, your other compressor... jlevy Texas Impreza Club Forum -- TXIC 25 07-08-2003 12:21 PM
