Old 04-24-2008, 12:09 AM   #1
WhiteH2O
Member#: 452
'06 GX470
Default Clock in an '02 WRX
My wife is wanting me to try to fix the clock in her WRX. The one in the dashboard. It just up and died yesterday, and isn't working at all. Nothing. No lights.
Aside from pushing buttons (that is not doing anything), what can I do before I start taking the interior apart to try to find out what is wrong with this thing? Are these known for going out or is there an easy fix to restart the thing?
WhiteH2O is offline   Reply With Quote
Old 04-24-2008, 12:04 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check the fuses in the panels under the dash and the under the hood. If those are ok then check to see if power is getting to the power lead for the clock. The clock itself may be the problem. There has been a lot of problems with the clocks due to bad solder joints on the board. Particularly, to a resistor in the power circuit. By resoldering the connection the clock can work again, if that is the problem with yours also.
Old 04-26-2008, 01:28 PM   #3
jace2k5
Member#: 107964
2004 WRX Wagon
Platinum Silver Metallic
http://forums.nasioc.com/forums/show...2&postcount=13
hey guys.. this is actually a pretty common problem with the 02 clock.. i almost purchased an 02' a few months ago with a dead clock and the dealer said it was about 75 to fix..
i then looked it up online and found this :
http://www.rowejason.com/2007/02/sub...-clock-fix.htm
also mentioned here:
http://www.scoobymods.com/forums/sho...ighlight=clock
quoting myself +1
quoting myself +2
jace2k5 is offline   Reply With Quote
Old 04-26-2008, 01:35 PM   #4
WhiteH2O
Member#: 452
'06 GX470
None of those links work for me.
The clock seems to work on and off, but mostly off. Seems to point to a loose connection (bad solder) or something.
Old 04-26-2008, 01:41 PM   #5
jace2k5
Member#: 107964
2004 WRX Wagon
'05 WRX Radiator fit in an '02 WRX? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 01-20-2006 09:04 PM
98 Impreza rear in an '02 WRX? ejsportcom Transmission (AT/MT) & Driveline 0 09-09-2005 07:27 PM
Heated seats in an '02 WRX?? Autologic Interior & Exterior Modification 8 08-22-2005 11:15 AM
Swap what in an '02 WRX? DirtyScooby Subaru Conversions 4 09-12-2004 03:03 AM
('93-'01) World sideways driving record attempt in an '02 WRX AlexM Impreza Forum 21 06-16-2001 01:15 AM
