Old 04-24-2008, 02:12 AM   #1
KevinM
Member#: 40511
02 WRX
Blue Pearl
Talking Used Oil Analysis - Redline 10w40 - 2002 WRX
Here is my recent analysis on the wife's '02 WRX wagon, Redline Oil 10w40 with 6,800 miles and ZERO make up oil added. Pretty easy driving, mostly city. The older analysis listed is of Royal Purple 10w30, but there was a crack in the air box which caused the high iron. I will be sticking with the Redline oil.
Pretty happy with the results.
KevinM is offline   Reply With Quote
Old 04-24-2008, 10:14 AM   #2
bluesubie
Member#: 767
04 FXT
Your wear is too low and you need to drive the car much harder.
Usually people say that you can go with a lower viscosity with Redline because it's such a robust oil.
Why did you go with 10W40? Because SD = hawt? Was there much difference in turbo spool and fuel economy in comparison to the 20 weight you had in there? Or does your wife let you drive it? I would stick with this since it's working well for you.
-Dennis
Old 04-24-2008, 10:47 AM   #3
Timdog1650
Member#: 45516
MY04 STi
Very nice UOA. It's always fun when they tell you that not only is your engine fine, but you can save yourself some money on oil changes. Win/Win.
Timdog1650 is offline   Reply With Quote
Old 04-24-2008, 12:42 PM   #4
AllWheelsDriven
Member#: 1737
2005 BMW zhp
www.vispoint.com
looks great....check out those viscosity numbers vs rp
AllWheelsDriven is offline   Reply With Quote
Old 04-24-2008, 01:04 PM   #5
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
So, BS didn't know why iron wear was so much lower, huh?
Have you seen recent VOAs on each of these two oils?
Interesting that an intake leak would raise Fe wear but not hard-metal wear...
Nice improvement. Good work repairing the intake crack.
bulwnkl is offline   Reply With Quote
Old 04-24-2008, 02:11 PM   #6
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Ah, I read that on BITOG last night If I could only remember my login and password there, I would have posted hehe.
JamesWilson is offline   Reply With Quote
Old 04-24-2008, 03:35 PM   #7
bluesubie
Member#: 767
04 FXT
The RP viscosity is normal. 10W30 sheared to a 20 weight.
-Dennis
Old 04-24-2008, 08:27 PM   #8
AllWheelsDriven
Member#: 1737
2005 BMW zhp
www.vispoint.com
^^ lovely
Old 04-25-2008, 01:09 AM   #9
KevinM
Member#: 40511
02 WRX
Blue Pearl
No sweat James, got you covered.
Old 04-25-2008, 01:09 AM   #10
KevinM
Member#: 40511
02 WRX
Blue Pearl
-Dennis
Yep, the Royal Purple from the prior UOA was 10w30.
Old 04-25-2008, 02:22 AM   #11
JamesWilson
Member#: 124833
2000 Legacy Wagon
Oh crap, hey Kevin! You get around, don't you? Sell the Porsche 951 yet?
Back to the Redline, looks like it held up very well and stayed a relatively-40wt. I wonder if there is a benefit of the Euro 5w-40 over the 10w-40 for next time? Probably not...find something you like and stock up!
Old 04-25-2008, 07:42 PM   #12
KevinM
Member#: 40511
02 WRX
Blue Pearl
Still have the Porsche, you should buy it! It just sits in my garage while I drive my 11 mpg Jeep to work.
What is the difference between the euro and the 10w40. I figure it is better to stick to the 10w40 vs a 5w40 in this town, the car never sees below 30 degrees.
Old 04-25-2008, 09:53 PM   #13
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
What's the difference? The 5W40 uses at least a little VII, the other Red Line formulations don't. Well, they didn't. Haven't taken a look in a couple years and all kinds of formulations have been jacked around by lots of people to try to maintain price points.
Still, the 5W40 will flow better, perhaps much better, when cold. Cold being defined as the period between startup and full oil operating temp, not just low ambient air temps.
Used Oil Analysis - Pennzoil Platinum 5W-30 - 2005 Subaru WRX STi AndyH Service & Maintenance 16 03-10-2008 10:30 PM
Used Oil Analysis - Amsoil ASL 5W30 - 2005 Subaru WRX STi alanlcit Service & Maintenance 30 01-23-2008 08:06 PM
Used Oil Analysis - Castrol Syntec 10W40 - Subaru WRX STi, 2nd sample alanlcit Service & Maintenance 8 10-23-2007 10:54 AM
used oil analysis results 2002 WRX what do you think? nicknaz Service & Maintenance 5 10-16-2007 03:35 AM
Used Oil Analysis - Castrol Syntec 10W40 - Subaru WRX STi alanlcit Service & Maintenance 19 07-24-2007 04:09 AM
