Old 04-24-2008, 10:20 AM   #1
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Default Tightening oil filter
When you tighten the oil filter, is it "OK" to just tighten it with your hands. Meaning, making sure it is snug. Without using any tool??
shamrock 05 is offline   Reply With Quote
Old 04-24-2008, 10:21 AM   #2
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
it is OK to do so.
i do it on all my vehicles.
however, i may be stronger than you.
Tahoe SC is offline   Reply With Quote
Old 04-24-2008, 10:23 AM   #3
Roamrex
Member#: 171487
06 WRX Wagon
SGM
you are not suppose to use a tool when tightening. after the filter gasket makes the slightest contact with the base after screwing it down, then turn 3/4 to 1 turn more and your set
Roamrex is offline   Reply With Quote
Old 04-24-2008, 03:51 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
You should NEVER need a tool to tighten it, even if you are a noodley armed 97 pounder... Roamrex has it correct, 1 turn after it makes contact is all you need. If you are used to cranking it down this will seem really odd, but the rubber gasket on the filter will swell when in contact with oil, so even though it feels a little loose now, it will soon tighten up, sometimes ALOT.
Old 04-24-2008, 04:17 PM   #5
sigurd
Member#: 128721
2002 impreza WRX
psm
its ok and its the way your supposed to do it.
99% of people tighten there oil filters too tight out of paranioa. Then they curse themselves when they need to remove it.
sigurd is offline   Reply With Quote
Old 04-24-2008, 04:54 PM   #6
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
I will be over tightening mine by hand for some time to come.
After finding i burned a hamburger size puddle of oil on my downpipe, and this was just from dropplets continually getting in the down draft pelting the Dp after going WOT several times.
dingobite is offline   Reply With Quote
Old 04-24-2008, 05:10 PM   #7
shamrock 05
Member#: 120057
Me^^^^^ not any more though
how much oil will i loose,?? have to remove oil filter again to tighten sndwch adapt Dr. octagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-28-2009 10:01 AM
Tighten and Double Check Your Oil Filter!!! Basshead Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 01-12-2006 01:39 PM
09A!! Tighten and Double Check Your Oil Filter!!! Basshead North West Impreza Club Forum -- NWIC 7 01-10-2006 12:25 AM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 08:25 AM
Oil and oil filter? Spark plugs and air filter? TimCat General Forum Archive 5 01-18-2001 11:27 PM
