Welcome to the North American Subaru Impreza Owners Club Saturday July 26, 2014
Closed Thread
Old 04-24-2008, 02:46 PM   #1
s0ber_p
Member#: 172689
2004 WRX
Default Slight problem with a few electronics....
My 04 wrx didnt come with a OEM boost gauge so I decided to splurge on a gauge and clock pod. I decided to do the installation myself and didn't have any problems with it. I came as a light up gauge so I took the lighting and ground off of the clock to use for the gauge and it works great. However, now my radio, dome light, map lights, the odometer trip resets, and the alarm system don't work. I was wondering if anyone knows if I disrupted a circuit or if there is another problem I am not seeing. Thanks in advance!
s0ber_p is offline
Old 04-24-2008, 03:15 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You probably blew a fuse. I don't remember offhand which one that would be but check in both fuse boxes- under the dash and under the hood.
Mulder is offline
Old 04-24-2008, 03:46 PM   #3
s0ber_p
Member#: 172689
2004 WRX
I check all of the fuses and didn't find any blown....startred out by checking the radio one, it was fine. So went ahead and checked every single one, both under the dash and in the engine compartment...
s0ber_p is offline
Old 04-24-2008, 05:17 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Verify that fuse #2 in the main panel under the hood has power getting through it, by using a voltmeter or test light probe and, testing both sides of the fuse by checking the voltage at access holes on the top of the fuse.
Cougar4 is offline
Old 07-04-2008, 12:22 AM   #5
ilitical
Member#: 183801
Im having the same problem but i installed a new head unit.
My dome lights, clock, and alarm arnt working, i checked all the fuses and all are fine.
any help?
ilitical is offline
Old 07-04-2008, 07:17 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please don't bump old threads, you already posted this once.
Mulder is offline
Closed Thread
01 2.5RS Problem with a few things.. xjoewhitex Newbies & FAQs 12 03-11-2009 04:52 PM
Slight problem with coilover install family_wagon Newbies & FAQs 8 08-16-2008 07:36 PM
slight problem with Redline light weight Shockproof WRX11 Mid Atlantic Impreza Club -- MAIC 16 01-20-2006 05:27 PM
Looking at 2002 WRX with slight problem... kahtep General Community 8 05-14-2005 06:29 PM
Slight problem with my Turbo timer - help! djerickd Factory 2.0L Turbo Powertrain 2 09-26-2001 12:06 PM
