Old 04-24-2008, 05:39 PM   #1
MrMakesitRain
Member#: 168333
2006 STi
CGM
Default Quick Question about HID wiring. i searched already.
i read maybe 30 different threads before finally deciding to post. i already disabled my drl's. now i just need to put in the new headlights and wire the HIDs.
everything is pretty forward but what do i do with these prongs? i know im going to need power and and a ground but where EXACTLY do i place these. ive read different things about not grounding. i just want to make sure i have everything straight before doing it and blowing something. i circled the things im talking about
MrMakesitRain is offline   Reply With Quote
Old 04-24-2008, 06:44 PM   #2
manookie
Member#: 125495
06 Wrx
SGM stg 5+4-7
Those are the wires that power the ballast and bulb. inside your headlight, the plug that was on your old bulb.... those plug into that. You probably want to make a wiring harness with a relay to draw power off your battery and not the oem wiring.
manookie is offline   Reply With Quote
Old 04-25-2008, 01:38 AM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
you need to fill out your profile so that we know what type of car you drive.
THEN we can help you with wiring.
Ninja edit: .... duhhhhh, you drive a bugeye. haha my bad
just so you know, you dont have highbeams anymore.
the red prong is going to go into the center terminal of the stock headlight plug. the black is going to go into the right hand side terminal. (this is when the round part is facing up, if i am not mistaking)
this should only be temporary. you really need to use a relay to power the ballasts.
jdubya301 is offline   Reply With Quote
Old 04-25-2008, 05:15 AM   #4
MrMakesitRain
Member#: 168333
2006 STi
CGM
okay i put everything together after using a grinder to make the prongs fit (they were too wide originally) everything works but id like to go a different route maybe use a special harness just to be safer. where can i get one at?
also right now my highbeam light on my gauge cluster is lit, not all the way but lit enough that it seems like its on.
thanks for all the help.
Old 04-25-2008, 11:14 AM   #5
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
pm lightwerkz, he can build you a harness. he does awesome work.
as for the highbeam light, do you have your DRLs removed? if i remember correctly, completely disabling the DRLs will get rid of the light.
Old 04-25-2008, 06:07 PM   #6
MrMakesitRain
Member#: 168333
2006 STi
CGM
i unplugged the drl harness behind the glovebox. is there anything else i need to do?
Old 04-27-2008, 11:46 PM   #7
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
i have both the drl harness and the resistor in the engine bay unplugged. duno if the resistor needs to be removed or not
Old 04-28-2008, 04:56 PM   #8
MrMakesitRain
Member#: 168333
2006 STi
CGM
i realized the high beam light only goes on when my fogs are activated. if that makes any sense.
Quick question about Audio wiring diagram lh0628 Car Audio, Video & Security 8 05-15-2009 11:07 PM
Quick question on HID Wiring CRL1084 Electrical & Lighting 7 06-03-2006 07:19 AM
quick question about output wire length 2003Baja Car Audio, Video & Security 2 11-14-2004 05:03 PM
Quick question about speaker wiring. Thead Car Audio, Video & Security 1 10-10-2002 07:35 PM
quick question about stage0 unichip wire connectors titsataki Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-09-2002 11:11 AM
