Old 04-24-2008, 05:51 PM   #1
TJRCS
Member#: 59199
2008 STI
Default Fuel leak only when fuel tank is full
Somewhat weird...
Whenever I fill up gas full tank, I can smell gasoline and see very small fuel dripping on the fuel tank. When the fuel tank goes below around 3/4 full mark, the smell and leak go away. Since I found this pattern, I usually fill it up to 3/4 full now. This prevents any leak problem.
I changed fuel pump gasket, but this won't solve the problem nor make any better. I used 3 cans Torco right before this happened (I used 1/2 can per full tank).
Possibly problems with evap system??
TJRCS is offline   Reply With Quote
Old 04-24-2008, 07:39 PM   #2
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
check your tank! see if theres hole or nothing!
have to fix it leaking fume to atmosphere is no good...lol
just go to any local shop and they are gonna check with fume sniffer!
EJ20_lee is offline   Reply With Quote
Old 04-28-2008, 12:50 AM   #3
TJRCS
Member#: 59199
2008 STI
any other suggestion?? dealer is asking $140 for just diagnosis
Old 04-28-2008, 05:05 AM   #4
mopartodd
Member#: 164929
2014 Impreza Premium
Jasmine Green Metalic
Perhaps where the filler neck goes into the tank....sending unit, or fuel return lines.
Just a thought. Good luck.
mopartodd is offline   Reply With Quote
Old 04-28-2008, 09:35 AM   #5
cMags
Member#: 88668
'05 Outback Sport
5MT - Regal Blue / Grey
Outback Sport
It might be the filler neck - my brother had one rot out on him so it would leak over a half tank. You might be able to smell fuel under the car while filling up - maybe have a buddy pump while you look under by the filler see if it gets wet w/ fuel (too difficult to smell for it at the pump).
cMags is offline   Reply With Quote
Knock only when A/C is on? pbomers Open Source Reflashes 13 08-06-2010 06:22 PM
p0440 only when tank is 1/2 full or less cjfike Normally Aspirated Powertrain 10 04-30-2009 07:48 PM
Coolant leak, only when warmed up. ZoomnWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-02-2007 02:21 PM
Hitt some sort of Fuel Cut only when taking a hard bend??? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 07-19-2005 12:16 PM
Losing reception in radio signals, but only when the engine is on? JjSwee Car Audio, Video & Security 3 01-06-2005 11:49 AM
