Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 04-05-2008, 02:41 PM   #1
mprother
Member#: 176401
Default ABS light on?
Anybody know what the ABS light means on a 05 sti? The manual is not very clear. Could it be the front pads being to low?
Thanks,
-Mike
mprother is offline   Reply With Quote
Old 04-05-2008, 02:42 PM   #2
sexycat
Member#: 173984
04 wrx
Ej25 vf39
ABS's problem..
sexycat is offline   Reply With Quote
Old 04-05-2008, 02:48 PM   #3
Howl
Member#: 57830
It's not worn pads. Check the ABS fuse. If it's not that get it looked into professionally.
Howl is offline   Reply With Quote
Old 04-05-2008, 04:04 PM   #4
mprother
Member#: 176401
I check to see if there were ECU codes and none came up.. Also checked the fuse, It looks good. The front pads are worn and squeaking, so there is no sensor that would go off if they were worn?
Thanks,
-Mike
Old 04-05-2008, 04:07 PM   #5
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
No one can tell you unless it is diagnosed. No a normal scan tool can not pull codes. You will need one that can.
blackfang is offline   Reply With Quote
Old 04-05-2008, 04:14 PM   #6
jasonallenross
Member#: 125978
2002 WRX Wagon
It means there is a fault in the system. If the fuse looks good, it could be pretty much anything from a malfunctioning sensor to a broken wire.
As for your worn and squeaking pads, if they are close to worn out, do the job now before it gets much more expensive.
jasonallenross is offline   Reply With Quote
Old 04-05-2008, 04:57 PM   #7
Jaylyons1
Member#: 113884
1989 Skyline GT-R
I had this light come on when some ice had built up in between the pad and disc. Maybe somethin is lodged in there? Hopefully its not more serious...
Jaylyons1 is offline   Reply With Quote
Old 04-06-2008, 12:06 AM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It means something is wrong with your ABS (d'oh!).
More specifically, the ABS controller has detected a problem and set a trouble code, much the same as the ECU will do with an engine/sensor issue. To read ABS codes requires either a scanner which only a dealer will have, a standard OBDII scanner can only connect to the ECU and not to the ABS controller.
Old 04-23-2008, 01:46 AM   #9
blaze9489
Member#: 173732
2004 WRX STi
Blue Ridge Pearl
sorry to bring up this dead thread but does anyone have anymore information on this problem? i also have the ABS light on an 04' sti swap i recently purchased. i also have the utek piggyback on it.
blaze9489 is offline   Reply With Quote
Old 04-24-2008, 08:48 PM   #10
WR Boxer
Member#: 171395
2004 STi
Java Black Pearl
My ABS light came on when I was crusin up in the hills in some thick snow. I got stuck and had to rock the car out of it and then just mash the gas, snow built up in the sensor and the light came on. Once I got down to dry pavement and got my tires spinning it went off after a while. You been doing any snow/dirt driving recently?
WR Boxer is offline   Reply With Quote
ABS light on, what sensors trigger it? wheel ABS sensor, speed sensor, what else? kirbykirb Legacy Forum 4 06-19-2010 11:37 PM
ABS light on, diagnosed with a front right ABS hold valve malfunction C-daleRidr Service & Maintenance 0 09-04-2007 04:39 PM
ABS light on 2001 Impreza 2.5 RS salaki Texas Impreza Club Forum -- TXIC 15 05-15-2002 11:19 PM
ABS light on after over-revving engine? dead-eye Brakes, Steering & Suspension 4 01-31-2002 07:45 PM
Help...please...ABS light on and I don't know why Cliff Ditchhanger Brakes, Steering & Suspension 6 04-16-2001 10:23 AM
