Old 04-25-2008, 10:55 PM   #1
RoadTrippin
Member#: 161175
Question Coolant Seepage?
Backing out of the garage today I noticed maybe a drop or two of coolant underneath my car. I decided to investigate, I noticed that where the lower radiator hose meets the engine block there is coolant collecting on part of the block. There is no coolant coming from the hose or any other part of the cooling system, just this small area by where the lower hose connects to the block. I wasnt able to get a good look tonight but would this be something along the lines of a bad gasket, bad water pump, or am I looking at something a bit more like a cracked block?
TIA
Dave
RoadTrippin is offline   Reply With Quote
Old 04-26-2008, 06:14 PM   #2
RoadTrippin
Member#: 161175
ideas???
Old 04-27-2008, 10:51 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
has the car overheated at all?
how many miles on the car?
what kind of maintenance have you done?
Jamie
Old 04-27-2008, 12:08 PM   #4
RoadTrippin
Member#: 161175
Never hit the red as far as overheating, went towards the upper end of the 'acceptable' range when I had a leak in my rad. about two months ago (been replaced since then and has never strayed from the middle) but never made it to the point where the needle shot up to red and white smoke would pour out.
101k as of this morning, Im going to end up replacing the water pump with the timing belt next week anyways but wanted to figure it out before hand.
Maint...regular maint done at proper intervals, only thing that hasnt been done that should is spark plugs as well as the spark plug boot gaskets due to a very small amount of oil on the spark plug boots.
Hope this helps.
Oil seepage above uppipe, diagnosis?? foxboroxt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-29-2007 03:11 PM
cam flange seepage? Soupy944 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-29-2004 07:26 PM
Anal Seepage incorporeal Off-Topic 20 07-17-2004 04:26 AM
Engine oil seepage question gavinl Newbies & FAQs 5 05-07-2004 07:22 PM
switched to synthetic... bit of seepage normal? remarcable Normally Aspirated Powertrain 4 06-07-2001 10:45 PM
