Old 04-26-2008, 12:46 AM   #1
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Default Engine knocked REALLY bad after sitting for 4 days
Okay, so I have put in 10W40 penn oil in my car. I noticed my gas milage go from ~20 to ~15. Also, I left town for 4 days and when I started my car after it sitting for the 4 days, it knocked as if I had a bearing completely disintegrate. After about 5 seconds it mellow out and went away. I assume it just needed a good oiling to calm down, but I was a little freaked out cause I just rebuild my motor after spinning a bearing.
Outside temp was ~45 degrees F.
Would this thicker oil really drain from all the joints in just 4 days?
Should I be concerned with how bad it knocked, and assume damage was done?
Any thoughts that I have not thought of?
Thanks!
paintbing is offline   Reply With Quote
Old 04-26-2008, 03:21 AM   #2
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
I've had that happen to me before in a '91 Subie. It's an oil starvation problem. First thing I'd try if it was me is waiting to see whether it ever happens again. Next thing I'd try is a new oil filter and maybe changing to a thinner oil. There's a few reasons why it may have happened. If it happens again, definitely change oil and filter and use a thinner oil. Try 5W30 where you live.
bulwnkl is offline   Reply With Quote
Old 04-26-2008, 04:08 AM   #3
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Sounds like cold piston slap to me.
lancelucas is offline   Reply With Quote
Old 04-26-2008, 04:42 AM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....or possibly slap from the timing belt due to the tensioner. I had it happen to me as well. Everything has been fine since then and after reading around (and the fact that I have another symptom indicative of the tensioner), I'm assuming it just happened to get stuck for a few moments.
Kean is offline   Reply With Quote
Old 04-26-2008, 07:15 PM   #5
Arctic Penguin
Member#: 119532
2006 WRX
i had a bad belt tensioner and it sounded for all the world like the motor was done on a cold start
it wasnt
Arctic Penguin is offline   Reply With Quote
Old 05-08-2008, 09:51 PM   #6
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Thanks! It hasnt happened again btw.
Old 05-08-2008, 11:54 PM   #7
Arctic Penguin
Member#: 119532
2006 WRX
mine did it once
then again
then more frequently
there is a hydraulic piston on the tensioner which goes bad
sometimes quickly
sometimes slowly
Old 05-09-2008, 10:27 AM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
.....yeah, it's been probably about 9 months since mine did it that one time.
Old 05-09-2008, 12:27 PM   #9
Arctic Penguin
Member#: 119532
2006 WRX
cool/cold weather usually precipitates this issue
Old 05-09-2008, 01:18 PM   #10
BGPKR
Member#: 41842
2006 LGT LTD 5SM
Mine has done it on a few occasions. But, only when it sits for a week or so. I would definitely like to know what this is. It doesn't sound good.
BGPKR is offline   Reply With Quote
Old 05-09-2008, 04:22 PM   #11
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
are you using an aftermarket oil filter, possibly one without a anti drain back valve. why are you running 10w40.
Please help!! Stranded after letting my car sit for 10 days!! silence2-38554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2010 04:01 PM
Car won't start after sitting for a few days thuan86 Electrical & Lighting 3 09-01-2007 12:21 AM
Auto won't go into gear after sitting for 3 months glennfabf Transmission (AT/MT) & Driveline 2 08-09-2005 06:57 PM
Blinking CEL at startup after car sat for 4 days djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-28-2003 07:14 PM
Car not starting well after sitting for a day... heat? New battery? remarcable Normally Aspirated Powertrain 17 07-13-2001 05:34 AM
