Old 04-26-2008, 04:03 AM   #1
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Default Oil Leak on Driver's Side after EJ257 Hybrid Build
Putting this one to my fellow NASIOC 'ers -- I'm nearing the final straw on this
So, my EJ257/Hybrid has a runny nose. Runny left nostril, I guess, to be technical. My longblock assembler and I have exhausted our brain power trying to solve this short of pulling the engine for inspection.
EJ257 SB
EJ205 Heads with STi Cams
JDM 12mm Oil Pump
Lots of other crap that shouldn't matter
It leaks out somewhere out of the driver's side front. The oil drips out of the timing belt cover on the driver's side. We just tore it completely apart and inspected all of the cam seals, the main seal, all of the plugs in the heads, etc. Other than a perhaps teeny-weeny-kinda-leak on one of the cam seals, which got replaced to be safe, there were no signs of the leak, other than oil everywhere. There was oil all over the timing covers, the gears, belt, etc. Everything seemed in order with the idlers and tensioner, but I'll admit we didn't consider the tensioner as a potential source until after reassembly.
It seems specifically driver's side oriented, but we have checked and re-checked the cam seals and such. What have we missed?
lancelucas is offline   Reply With Quote
Old 04-26-2008, 05:44 PM   #2
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Nobody?
Old 04-27-2008, 12:07 PM   #3
illlwilll
Member#: 142636
2004 WRB WRX
2000 Yamaha R6
Is the additional cc breather port on the STI shortblock capped... if so, that may be the issue; if i'm not mistaken, that breather is there to equalize the the pressure between the crankcase and the heads.
illlwilll is offline   Reply With Quote
Old 04-27-2008, 03:48 PM   #4
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
It is capped...but how would that force oil out of the head?
Old 04-27-2008, 05:04 PM   #5
illlwilll
Member#: 142636
2004 WRB WRX
2000 Yamaha R6
I believe that port is supposed to equalize the pressure between the crankcase and the heads... I don't know enough to explain the specifics but i capped my breather and I am also have the same issue with the leaking cam seal
I searched this forum for a few days and I found that a number of people with these 2.5l hybrid motors either leaked or blew cam seals due to too much pressure building up in the heads.
I'm thinking about T-ing a line from the breather and tapping both valve covers but i'm not sure if that will affect the vacuum so i'm still researching.
here's my original thread by the way
http://forums.nasioc.com/forums/show....php?t=1473602
Old 05-09-2008, 07:08 PM   #6
saggioWRX
Member#: 18994
08 GTS
10 CTS W
Who cares...
saggioWRX is offline   Reply With Quote
Old 05-09-2008, 07:26 PM   #7
illlwilll
Member#: 142636
2004 WRB WRX
2000 Yamaha R6
Originally Posted by saggioWRX View Post
Who cares...
I suppose anyone doing a hybrid build
Old 05-09-2008, 09:20 PM   #8
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Who cares...
evidently not you, so why respond.
But for the op. Open up the breather you have capped off, it is a place to start and it will not hurt any thing by doing so.
flstffxe is offline   Reply With Quote
Old 05-28-2008, 02:06 AM   #9
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Who cares...
Thanks for the bump!
Thanks for the advice. I ended up doing this; I tee'd it into the head breather lines. The oil leak hasn't seemed to slow much from this and I still leave a nice puddle wherever I park. The best part is when the drips hit the header heat shields and the cloud starts rolling out from under the hood
I'm at a total loss. Pretty much ready to drop it off at a shop with the "don't call me till it's done" story. Any and all ideas welcome...
Old 05-28-2008, 08:41 AM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
put dye in the oil, check with a black light, any engine builder should know to do this, easy way to trace where the oil came from.
Old 05-28-2008, 10:23 AM   #11
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
check your cam seals. Good luck and let us know
WRX4eva is offline   Reply With Quote
Old 05-01-2014, 10:05 AM   #12
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
I hate how threads like this go dead so much on NASIOC. I have this exact same issue and have found not one but two threads where no one posts the resolution.
If anyone is still subscribed to this thread who knows the outcome of this issue, please respond even though it's been 6 years lol.
BrandonDrums is offline   Reply With Quote
Old 11-24-2014, 03:34 PM   #13
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
One of the plugs in the end of the STI intake cams to delete AVCS was leaking. Fixed that and things were good to go.
Old 11-25-2014, 04:42 PM   #14
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Nice!!!
A resolution.
Sent from the twilight zone.
Bikelok is offline   Reply With Quote
Exciting New Head Option for EJ205/EJ257 Hybrid Builds! Equilibrium Tuning Built Motor Discussion 524 12-13-2015 12:04 AM
ej257 hybrid build imc343 Newbies & FAQs 3 05-06-2010 01:58 PM
FS: 2002 WRX 2.5 EJ257 Hybrid Build 02WRXmoddedrex Private Vehicle 'For Sale' Classifieds 3 04-14-2010 09:25 PM
6MT leak from pipe on driver's side Patrick Olsen Transmission (AT/MT) & Driveline 4 02-01-2010 01:16 PM
'01 2.5RS - Coolant Leak on Driver's Side esbee Normally Aspirated Powertrain 5 11-19-2007 10:36 PM
