Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-26-2008, 06:06 AM   #1
shinta-wrx-
Member#: 11935
2002 WRX/C63
blue/white
Default high pitched whine coming from the turbo
Hi all,
I against my better judgment brought in my wrx a few years back to Midas when a check engine light came on randomly. When they initially tested it they said they couldn't find anything wrong and simply reset the ecu, of course within a day the CEL came back on. Apparently the problem was the temperature sensor, which they replaced.
When I got my car back everything seemed fine until I revved past 3000 rpm. Whenever the turbo activates a high pitched mechanical whine emanates from the engine bay. The sound is similar to a supercharger and is quite loud when you're outside the car. When driving the car hard, I don't notice any power loss, or anything that seems imminently destructive. Just a high pitched jet turbine like noise.
Has anyone had a similar experience? What could be wrong?
shinta-wrx- is offline   Reply With Quote
Old 04-26-2008, 11:56 PM   #2
rexyrex
Member#: 169205
that "whine" you're talking about is the turbo spooling faster. its a good sound
rexyrex is offline   Reply With Quote
Old 04-27-2008, 01:57 AM   #3
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I would check a couple of things. Check to make sure that where the intercooler Y-pipe mounts to the turbo, that it is mounted correctly andthe clamp tight. Also check for little cracks here that could be leaking boost. I had this exact situation with a customers car once. THe hose was rolled and not on the turbo properly. fixed that only to find the intercooler y-pipe split.
Also check where you tubo inlet mounts on the front of your turbo, for similar incorrect mounting and cuts in the material.
bmxpunk is offline   Reply With Quote
Old 04-27-2008, 04:46 AM   #4
shinta-wrx-
Member#: 11935
2002 WRX/C63
blue/white
thanks bmxpunk I'll take a look at that.
rexyrex, If it were merely the 'turbo spooling' faster I wouldn't mind, but it is an ungodly high pitched mechanical whine. Unless during the first 4 years I owned the car the turbo never spooled up when I went WOT. I know when the turbo is fully spooled there is a mechanical whir, but whenever I hit 3000 rpm these days its like having a constant blow off valve sound but higher pitched and constantly increasing until I hit the redline.
Old 04-27-2008, 10:49 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
High Pitched Noise Coming From Engine Bay suds85 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-10-2009 06:31 PM
fluttering sound coming from the turbo ownnij Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-30-2008 07:34 PM
High pitched whining sound from my cable modem nt5k Off-Topic 14 01-21-2008 01:24 PM
High-Pitched Whine Coming from 4EAT Tranny...Minor Slippage...HELP!! JohnnyWas Transmission (AT/MT) & Driveline 8 04-17-2007 03:31 PM
High pitch sound coming from brake/suspension area txl146 Brakes, Steering & Suspension 4 05-08-2005 09:44 PM
