Old 04-26-2008, 12:05 PM   #1
ej20_876
Member#: 39660
2004 AW WRX - Built
2011 Toyota 4Runner White
Default Trouble-shooting my Philips H1 HID. Help needed.
I installed a Philips H1 HID system in my 2004 WRX about a year ago. Everything worked great until about 3 days ago. I noticed my driver-side headlight was not turning on. I open the hood and check the fuse: OK. I then look at the ballast and notice that the connection going from the ballast to the bulb was not connected. So, I figure this is the problem and plug it in. Ballast still does not power up and headlight does not come on.
I then look at the fuse again and notice it had blown. I replace the fuse with a new one and fire the system up. No luck.
I then piece apart the wiring harness and take the ballast out. I notice that the connections inside the ballast are wet. I don't know how this happened because they were well protected under the hood. Anyways, the connections somehow got wet and I am unsure as to what I should do to fix the problem.
I understand basic electricity and I understand that ions in the water would have been more that capable of causing a short.
Is my HID ballast bad, is the coil pack bad?
Any help would be greatly appreciated.
ej20_876 is offline   Reply With Quote
Old 04-26-2008, 01:28 PM   #2
ej20_876
Member#: 39660
2004 AW WRX - Built
Well... I opened up the ballast and it is fried =(
These new Philips ballasts were supposed to be corrosive tested and water-proof. What a scam.
Old 04-27-2008, 12:48 AM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
they are only water proof if the connectors are on, other wise you are missing a seal. just a thought.
Are you positive it is fried? first step i'd try would be swapping ballasts from side to side to be absolutely positive.
ProdriveDreams is offline   Reply With Quote
Old 05-04-2008, 08:14 PM   #4
ej20_876
Member#: 39660
2004 AW WRX - Built
The ballast is done. I swapped it to the other side and it didn't work. I contacted the distributor and this will be covered under warranty...
Old 05-04-2008, 08:50 PM   #5
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
Originally Posted by ej20_876 View Post
What a scam.
too bad. at least it will be covered under warranty.
Handsdown is offline   Reply With Quote
Old 05-04-2008, 10:59 PM   #6
GeoffSFAs10
Member#: 173996
its a fake philips. they do not make HID kits. somepne just put their name on a ****ty balast id bet.
GeoffSFAs10 is offline   Reply With Quote
Old 05-04-2008, 11:47 PM   #7
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
yeah i was thinking that but didn't want to bully the thread starter.
there are also fake hella ballasts. the whole kit market is full of seedy backhanded sleazeballs selling terrible expensive mistakes.
Old 05-05-2008, 11:30 PM   #8
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
and everyone wonders why HID kits suck.
props on getting one with a warranty tho.
jdubya301 is offline   Reply With Quote
Old 05-06-2008, 08:29 PM   #9
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
It's not just kits, most ballasts aren't meant to get wet, especially submerged. Factory xenon cars place the ballasts in waterproof locations. You should always find a location away from water (under the hood isn't good enough), face the electrical connections down when applicable and use dielectric grease on all connections.
ptirmal is online now   Reply With Quote
Old 05-06-2008, 10:24 PM   #10
GeoffSFAs10
Member#: 173996
wasnt trying to bash but thats just the way it happens sometimes. stupid chinese and anti copyright laws...
Old 05-07-2008, 08:19 AM   #11
ej20_876
Member#: 39660
2004 AW WRX - Built
I didn't know that Philips didn't make ballasts. I had always heard that Philips ballasts were trusted products. Well I guess I learned a lesson.
I knew there were a lot of shady HID dealers and kits, but I thought I was staying away from that by buying a Philips set-up.
Thanks for the info.
Old 05-07-2008, 09:46 AM   #12
GeoffSFAs10
Member#: 173996
they do make ballasts, which is the real stinker.
however, Phillips makes ballasts only for OEM applications because in the US HID kits are illegal. However, some companies to promote their products and get more attention will say they are using a phillips or slyvania ballast, when in fact they are just stickers saying such. it would be possible for you to have a phillips balast, but it would be connected to an OEM bulb, which an h1 is not, itd be a d2s or d2r.
from re-reading your orginal post and actually not offering any help in the beginning i'll say this. since the bulb connection was unplugged and the ballast connecters had gotten wet, the fuse then blew, your ballast is toast. they hate being wet and if they are they will arc and short out.
HID Help needed for my 02 wrx subielover29 Electrical & Lighting 5 03-27-2010 01:26 AM
Please help trouble shoot my limited WOT boost gad Factory 2.5L Turbo Powertrain 11 01-18-2009 08:03 AM
Help me trouble shoot my meth kit... SubieRX Water/Methanol Injection, Nitrous & Intercooler Cooling 4 05-27-2007 01:52 AM
Please help trouble shoot my engine noise Liam D Car Audio, Video & Security 5 07-28-2005 09:11 PM
2004 Hid Help Needed Phase315 Electrical & Lighting 1 03-19-2004 10:23 AM
Message Board Statistics All times are GMT -4. The time now is 06:32 PM.
