Old 04-26-2008, 04:23 PM   #1
WRBLueGD2
Member#: 139108
2004 WRX
Default Access Port 2.0 Giving me Error Code 1014
Um, what's this? I bought this used from a guy with an 05 STi. Did he not uninstall in? Or he just decided to sell me a broken unit? Obviously Cobb tech support is closed during the weekends.
WRBLueGD2 is offline   Reply With Quote
Old 04-26-2008, 06:56 PM   #2
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
You have to give more info than that.
What were you doing? what firmware do you have? what point of the installation failed?
What car, is it in test mode? can it connect to the computer?
parker/slc/gc8fan is offline   Reply With Quote
Old 04-27-2008, 09:40 AM   #3
WRBLueGD2
Member#: 139108
2004 WRX
nnewest firmware, 04 stage 2 wrx, in test mode. it stops during map instillatio. can connect to the computer fine, get all the way to instillation in the car and it goes, nope!
Old 04-27-2008, 03:49 PM   #4
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
what part of installation? right after the map is chosen? when the map is being downloaded when the map is being flashed?
Is the AP new or used? what is you dongle info?
Old 04-27-2008, 03:52 PM   #5
WRBLueGD2
Member#: 139108
2004 WRX
Dongle info?
Like it says, I bought it used.
As I hit ok to install the map, the next screen I get is this error.
Model is AP-SUB-002.
It was advertised as -001 which is what I think I need for a 2.0L.
When I right click and hit "Identify Access Port" I get this under AccessPort Model: 2004 - 2007 USDM 2.5L Turbo
I'm pretty sure it was misrepresent and I have the wrong unit. Just my luck...
Old 04-27-2008, 03:58 PM   #6
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
connect the AP to the car and check about for you dongle info, post the firmare too if you can.
Old 04-27-2008, 04:07 PM   #7
WRBLueGD2
Member#: 139108
2004 WRX
Firmware v1.2.4.1-4983
So is this the correct AP for my car? There's a 2.0L and a 2.5L correct?
BRB with Dongle infoez
Old 04-27-2008, 04:18 PM   #8
WRBLueGD2
Member#: 139108
2004 WRX
Dongle Version 6.00
Under model info, it says USDM 2004 - 2007 2.5L Turbo. I have the wrong AP. Problem solved.
So now do I try to get my money back or resell it?
Old 04-28-2008, 11:16 AM   #9
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
that model AP should work, unless it is allready programed as installed. If that is the case, you will want to try and get your money back.
Your car is an 04-07 right? and it does have a 2.5 liter turbo, right?
Old 04-28-2008, 02:34 PM   #10
WRBLueGD2
Member#: 139108
2004 WRX
2004 and 2005 WRX are 2.0L
2006 and 2007 WRX are 2.5L
Pretty sure this is accurate.
I have the wrong Access Port. It's currently in the classified section and on eBay.
Access Port 2.0 for 2.5L aboothman Engine/Power/Exhaust 29 06-15-2009 08:26 PM
Cobb Access Port 2.0 Rippen Griffen News & Rumors 43 10-20-2006 04:16 PM
New Cobb Tuning Access Port 2.0 Spida AccessPort 6 10-17-2006 06:36 AM
New Cobb Tuning Access Port 2.0 Spida Vancouver Impreza Club Forum -- VIC 9 10-12-2006 05:51 PM
