Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 04-26-2008, 04:56 PM   #1
wopgenius
Member#: 153855
2008 Hyundai Elantra
Default High Mileage Oil in low mileage car?
Would using a high mileage oil, on a newer low miles car, have any positive affects long term on the engine? Just curious.
wopgenius is offline   Reply With Quote
Old 04-26-2008, 05:46 PM   #2
lionken07
Member#: 13660
04 WRX 5 speed
05 Impreza OBS
its called high mileage oil for a reason. Don't do it...
lionken07 is offline   Reply With Quote
Old 04-26-2008, 09:47 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
ask for oil opinions over here instead...
http://www.bobistheoilguy.com
In general the HM oils are fairly well regarded, INCLUDING the Mobil 1 varieties. They are usually thicker than the non-HM versions and may contain more detergents.
Old 04-26-2008, 10:04 PM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
There additives package also typically contain additives to keep the seals soft and pliable as seals tend to harden as time goes by. I don't at this time see any issues with running the HM oils in a low mileage engine. As long as you choose a the appropriate grade and weight for your application. It may actually lengthen the life of the seals that much more(shrug shoulders). Good question though, like rkramer said bitog is the place to start.
flstffxe is offline   Reply With Quote
Old 04-27-2008, 02:15 AM   #5
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
No. I have 133K+ miles on my wrx, and I wouldn't put "high mileage" oil in my car. But I don't have high miles anyway. I use dino oil 10w30. Car runs like the day I bought it 7 years ago. No oil consumption.
rexman2002 is offline   Reply With Quote
Old 04-28-2008, 09:38 PM   #6
ruggedman
Member#: 17590
2006 WRX Limited
WR Blue
When i went to the store one glorious oil change day they were all out of regular M1. I used the extended oil not even thinking twice, it's approved by passing the SAE tests required by subaru and it's the right viscosity as per subaru. I bought it, used it, and changed it. That was 12k miles and like 3 oil changes ago. I do UOA's and a check my oil levels EVERY gas fill up. I've never used any measurable amount of oil in my WRX, no need to worry about a re-badged oil. Life's too short to worry about a high mileage formula oil in a young car.
ruggedman is offline   Reply With Quote
Old 04-28-2008, 10:20 PM   #7
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
No.
<meaningless extra characters have been added to this post to meet minimum NASIOC requirements>
bulwnkl is offline   Reply With Quote
Old 04-29-2008, 05:03 PM   #8
wopgenius
Member#: 153855
Thanks for the answers. I am not going to do it, I was just pondering it. I thought if it is that much better for an older engine, why cant it be that much better for a new one? I'll stick with my synthetic and be just fine.
Old 04-30-2008, 04:29 PM   #9
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Sorry if this is late.
Do not use high-mileage oil in a moderately to low use car.
I switched from Mobil-1 in my Focus to Amsoil high-mileage oil. The Focus is a locally driven car that is stop & go. Within two weeks, the oil had the white swirls in it because of water accumulation from not being burned off due to the low use, stop & go use.
I switched back to Mobil-1 and have no water accumulation due to the low usage, no burn-off.
The high-mileage oil is designed so that if you're doing high driving miles in a relatively short period of time, you basically extend the mileage changing times.
Meaning, if say you do 6k miles in 6mos, you change the oil at the 6mos mark. If you did 6k miles in 3mos, you would change the oil at the 3mos mark. With the high-mileage oil, the idea would be that you do 12k miles in 6mos and then change it at the 6mos mark.
You get more for your money and more out of your existing resource pool.
From experience though, just don't use Mobil-1 in your Impreza.
Using later model 'centre diff' autos in early model cars BLSTIC Transmission (AT/MT) & Driveline 10 06-08-2010 02:04 AM
Help with high mileage oil - non subaru car yo14jman Service & Maintenance 11 02-07-2010 01:18 PM
Hi Mileage Oil in your wrx? trueno92 Newbies & FAQs 12 04-25-2006 12:29 AM
synthetic oil in an older car Mr.Sparkle Service & Maintenance 13 08-04-2005 07:40 PM
Anybody interested in low mileage, used KYB GR2's? whtlegacy Legacy Forum 11 03-24-2004 12:06 AM
