Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 04-26-2008, 05:37 PM   #1
Member#: 113686
Default How to disable ABS on 96 Legacy L
Long story short, I need to replace a broken tone wheel, but don't have the cash to pull the hub and have it pressed and have the tone wheel replaced right now.
I want to pull a fuse that will safely disable the ABS for now until I have the funds in a few weeks to get it fixed.
I read a post that said to pull the fuse under the hood that says ABS, but I looked and they aren't any.
There are two fuses in the front driver side pedal area, one says ABS/Cruise the other says ABS Relay
If I pull the ABS Relay will that safely disable ABS for now?
pmaryan is offline   Reply With Quote
Old 04-26-2008, 05:58 PM   #2
Member#: 127878
2004 Impreza 2.5TS
2014 XV Crosstrek
If the tone wheel is broken, I'm presuming that your ABS light is on. That means that the ABS is already disabled, and you don't have to pull any fuses at all.
But, in answer to your question, yes, pulling the ABS Relay will safely disable the ABS until it's plugged back in.
silver2004impreza is offline   Reply With Quote
Old 04-27-2008, 10:04 AM   #3
Subie Gal
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
ABS fuse is INSIDE the car in the in car fuse box
If you do not know where that is, grab your owners manual for help
How to pull abs codes from 96 impreza? simpreza2 Brakes, Steering & Suspension 0 09-04-2004 01:21 PM
How to disable DRL's in 2005 Legacy?? WRX-1977 Electrical & Lighting 23 08-09-2004 12:39 PM
05 Legacy GT--anyone know how to disable the DRL's??????? mhelouin Legacy Forum 5 07-16-2004 07:52 PM
How to disable ABS? lushboy Legacy Forum 8 04-13-2002 06:50 PM
