Old 04-26-2008, 07:24 PM   #1
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Default No dash 04 STI on startup etc, Help
I was installing a new radio and Blitz boost controller with Power meter. I hooked into my UTEC wiring for speed sensor and power from fuse box.
Problem
I don't have dash startup and no guages plus no headlights.
Car starts and runs fine with only the blinkers and open door red light coming on on the dashboard.
What have I done as all fuses look good.
I see the 2 green connects are unpluged which is right but there is a black connector also not plugged in, does it also sit idle like the greens or is it plugged somewhere.
Any help would be womderful
Wombat North is offline   Reply With Quote
Old 04-27-2008, 12:25 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
on my friends 02 WRX i did notice a little black connector not plugged in right near the test connectors. His **** works fine.
Pull the dash out, make sure all the connections are snug.
also did you do any wire splicing to install anything?
ProdriveDreams is offline   Reply With Quote
Old 04-27-2008, 01:00 AM   #3
Wombat North
Member#: 21267
STI, EWG 8cm Green
Dash has now been taken out and all connections look OK. No new splicing and battery was disconnected while I was working on it earlier
Also
No lights come on in the heat/air switches.
No DRL's work
No headlights
No Gauge cluster lights or Gauges except turn signals, door open and headligt green light, that's it.
All fuses removed and checked with a meter plus swapped to different positions.
Got to be a relay?
Old 04-27-2008, 01:53 AM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
i dont think there is a relay that runs all that, check em anyways cant hurt...
now the gauges dont work at all right? they dont jsut not light up?
Old 04-27-2008, 10:52 AM   #5
Wombat North
Member#: 21267
STI, EWG 8cm Green
The gauges don't light up or work, nothing
Old 04-28-2008, 11:25 AM   #6
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Have you checked the fuses in the panel under the hood also? This most likely is a fuse problem.
Old 04-28-2008, 12:37 PM   #7
Wombat North
Member#: 21267
STI, EWG 8cm Green
yes 12345
Old 04-29-2008, 04:57 PM   #8
Cougar4
Member#: 53443
Winestone
Have you verified that voltage is getting to the fuses under the hood? If they are ok, then check the dash fuses for power.
Where to tap Ignition On power on 04 STi? For gauges etc... LESLIEx317537 Electrical & Lighting 10 05-27-2015 01:05 PM
coilovers for WRX and 04 STI on ebay. No reserve auction oliwer78 Suspension/Brakes/Handling 7 03-18-2010 08:46 PM
Jumped Connector under dash 04 STI AmolaitoPR Electrical & Lighting 0 06-24-2006 09:35 PM
04 sti motor/ecu/etc 02WRX2.5 North West Impreza Club Forum -- NWIC 3 04-16-2005 11:36 AM
04 sti side splitters, etc.. dorien Private 'Wanted' Classifieds 1 03-23-2004 10:27 AM
