Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-26-2008, 07:49 PM   #1
DausWRX
Member#: 134429
02 wrx
blu
Default cleaned IACV prob
i just cleaned my IACV on my 02 wrx(stock) but after i started it up for the first time theres white smoke coming out the exhaust is this normal or is something wrong?? any info would help, thanks
DausWRX is offline   Reply With Quote
Old 04-26-2008, 08:49 PM   #2
ultramegaguy
Member#: 178011
i'd say it would be normal cause its probably just burning any cleaning residuethat was left in it
ultramegaguy is offline   Reply With Quote
Old 04-26-2008, 09:03 PM   #3
ultramegaguy
Member#: 178011
actually did you change the gasket cause if you didnt it might of broken and that white smoke could be coolant coming into your intake
Old 04-27-2008, 02:06 AM   #4
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
did you use reuse the old gasket? Weird I just did that a few weeks back and I had no white smoke. Only after the inital start up there was slight hick-up that's it.
rexman2002 is offline   Reply With Quote
Old 04-28-2008, 10:17 PM   #5
scooterforever
Member#: 55011
It is very important that the IACV gasket be properly seated and the IACV itself screwed down appropriately. If the gasket is torn, deformed (as old ones often are), or not properly seated (e.g., drive under vacuum without any boost for say 10 miles) you can get a) a boost leak, b) a vacuum leak, c) coolant flownig into the intake, or d) some combination of the above nasties.
scooterforever is offline   Reply With Quote
Cleaning And Reattaching The IACV (Idle Air Control Valve) scooterforever Service & Maintenance 540 08-16-2016 01:53 PM
help, low idle prob, iacv problem ncarn8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-25-2010 09:20 PM
Cleaned IACV then primed fuel pump, now car wont start!! blessed0903 Service & Maintenance 0 10-13-2009 04:18 PM
NEED: CLEAN iacv!! Flat4TW Private 'Wanted' Classifieds 0 05-16-2009 06:30 PM
Cleaned IACV, still getting P0508. Help? PatSti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-09-2007 12:27 AM
