Old 04-27-2008, 02:15 PM   #1
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
Default stainless steel bolts
Up to this day I don't understand why auto manufacturers don't install stainless steel bolts. At the very least, on parts that will require regular maintenance.
I just spend 45 minutes just replacing a fog light bolt and snapped 2 bolts because they were rusted, theres not even a way to put a zip tie on there. And I looked on the otherside..whenever that other fog goes I'll have to go through the same procedure.
Now I need to spend an hour drilling endlessly into those damn bolt.
Rayme is offline   Reply With Quote
Old 04-27-2008, 04:11 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
stainless steel Galls very easily and can/may be even worse to get out over time.
http://en.wikipedia.org/wiki/Galling
flstffxe is offline   Reply With Quote
Old 04-27-2008, 04:26 PM   #3
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
yea but I mean just the bolt, it's not going go gall against normal metal...no?
Old 04-27-2008, 08:59 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
the threads will gall against the nut/fastener given time and vibration. not to mention, $$$.
Old 04-27-2008, 11:40 PM   #5
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
You need to go in from the back with the fog bulbs. It's not easy but, much easier than dealing with the bolts in the front. Mine have been seized for about 5 years......
foxboroxt is offline   Reply With Quote
Old 04-28-2008, 06:30 PM   #6
flstffxe
Member#: 155358
2008 Forester
Steel Silver
It can still gall. Stainless steel can still be a soft alloy depending on the grade, 303, 304, 316, 17-4........They are not all created equally.
Old 04-28-2008, 08:14 PM   #7
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
well.. how about them nylon bolt then? ahaha...
Old 04-29-2008, 06:43 PM   #8
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^ I see no reason why not, low cost, easily machined, the right grade would more then hold. Long term durability may suffer as it ages and turns brittle. All things to consider.
FS: New Stainless Steel T-Bolt Clamps Ryans07STI SCIC Private Classifieds 9 03-08-2010 12:59 AM
stainless steel lines missing banjo bolts wrXiconZ Newbies & FAQs 4 02-09-2007 12:38 PM
Stainless Steel Exhaust Bolt Kits. YOU DON'T HAVE THEM! XWRATED Engine/Power/Exhaust 0 10-15-2006 05:13 PM
Stainless Steel Exhaust bolt kits XWRATED Private 'For Sale' Classifieds 9 05-24-2006 08:20 AM
what size stainless steel bolts to buy for cat back install? gsgleason Normally Aspirated Powertrain 1 05-07-2004 12:00 PM
