Old 04-27-2008, 03:17 PM   #1
jahl7787
Member#: 97326
04 sti
Default Common a/c leak points
Are there any? After refilling the system a few days ago it now blows out hot air, leading me to believe there is a pretty severe leak. Autozone sells leak detection kits (uv light, o-rings, & goggles I think), but they are like $50. Are there any points maybe under the car I should be checking? It sucks when it's 100+ degrees and you have to wear a suit to work.
jahl7787 is offline   Reply With Quote
Old 04-27-2008, 04:03 PM   #2
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
The line from the compressor to the condensor goes bad. If it's wet, there ya go. Condensors go back when there's rocks and objects puncture it(obvious, but still a good spot to look). Compressor snout(that connects compressor to clutch). A/C line that goes behind the intercooler. If you have an aftermarket intercooler(or bigger one for that matter), then it could have rubbed a hole in it. If you find anything wet, that's where the leak's gonna be.
Mika
finnRex is offline   Reply With Quote
Most Common exhaust leak points STIckySTIfee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-19-2008 08:13 PM
02 Fuel leak. i dont think its the common leak! Robstunner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-21-2007 12:23 AM
Common Failure Points in MY05 RS Wagons? williaty Motorsports 48 03-05-2007 10:00 PM
Valve cover leak common? GTR STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-11-2005 11:32 AM
Common oil leak problem?? Puyo Newbies & FAQs 1 03-14-2003 10:19 PM
