Old 04-27-2008, 06:13 PM   #1
onetoenvy
Member#: 167498
04 subi
blue
Exclamation Oil Line leak from Motor to Turbo
Ok... i beilive that the oil cooling line to the turbo has a problem...
This line has part that ataches to the turbo and part hat attaches to the motor and they meet in the middle with a fiiting... i seem to have a LOT of oil comming out at the fitting.. i too it off today and cleaned it reall good.. but it only seem to get worse... now its leaking down to the uppipe.. nd that is making a smokey stinky mess
onetoenvy is offline   Reply With Quote
Old 04-27-2008, 07:52 PM   #2
gtasti
Member#: 152036
2004 Sti
yea i would replace that asap if u.... u could rune the turbo if its not getting enought oil
gtasti is offline   Reply With Quote
Old 04-27-2008, 09:06 PM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I wouldn't be so worried about the turbo... I'd be more worried about the motor losing oil and grenading itself.
jigga is offline   Reply With Quote
Old 04-28-2008, 02:01 AM   #4
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Replace the whole line ASAP
Is this a WRX?
LeeC is offline   Reply With Quote
Old 04-28-2008, 08:02 AM   #5
2wickedWRX
Member#: 151211
2007 RWD STI
WR blue
first off fill out you info better than 04 subie
but if this is for a wrx i changed the crush washers on my oil line this weekend took me about 45 minutes. Replace the line and make sure to get new copper crush washers.
2wickedWRX is offline   Reply With Quote
Old 04-28-2008, 09:41 AM   #6
STIBungy
Member#: 51684
I bet there's a hairline crack in the line.
STIBungy is offline   Reply With Quote
Old 08-04-2008, 11:31 PM   #7
Fahren
Member#: 105016
2005 FXT
CGM
bump. i'm getting the same leak in the same spot, where the two lines come together.
any ideas how to fix this besides replacing the line? i.e. tightening the fittings? or putting a washer in there?
Fahren is offline   Reply With Quote
Old 08-05-2008, 12:33 AM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
If the hardline is cracked like they do sometimes, replacement is the only option. We would have expected you to try the obvious things like tighten leaky bolt and replace crush washers. What happened to common sense?
Old 08-05-2008, 10:03 AM   #9
gt_nky
Member#: 159718
2010 VW Golf TDI 6MT
Candy White
to keep it cheap, you might want to look into fabbing something similar
http://www.iwsti.com/forums/engine-p...placement.html
gt_nky is offline   Reply With Quote
Old 08-05-2008, 12:26 PM   #10
Fahren
Member#: 105016
2005 FXT
CGM
i've replaced both the crush washer on the oil to turbo connection. thanks for the insult to my common sense, mr "scooby specialist"
but what i asking was more directed toward the middle connection, and how that piece works, whether you can just tighten it up, and how, or if you can pull it apart and place a washer in there and put it back together.
i've looked at the connection a bit but can't exactly tell how to comes together or tightens up. WHICH IS WHY I ASKED MY LACK OF COMMON SENSE QUESTION.
but thanks for wasting your time anyways.
Old 08-05-2008, 12:27 PM   #11
Fahren
Member#: 105016
2005 FXT
CGM
awesome. thanks for the link.
Old 08-05-2008, 12:34 PM   #12
Fahren
Member#: 105016
2005 FXT
CGM
so total cost for suave looking DIY parts is roughly 80.
who paid full price from the dealer to replace this part? what was the cost?
Old 08-05-2008, 12:47 PM   #13
WReX4
Member#: 62215
2006 Sti OBP
dom3
my guess is the OEM line has a crack in it.
WReX4 is offline   Reply With Quote
Old 08-05-2008, 01:04 PM   #14
Fahren
Member#: 105016
2005 FXT
CGM
i don't actually think it's cracked. it looks more like it's leaking out of the connection in the middle. but i'll check for hairline cracks.
Old 08-05-2008, 02:06 PM   #15
48mpg
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
thats pretty much what i did when i cracked my line
48mpg is offline   Reply With Quote
Old 08-15-2008, 07:47 PM   #16
Fahren
Member#: 105016
2005 FXT
CGM
Anyone know what the dealer charges for a new oil line?
Old 08-24-2008, 10:05 PM   #17
elazulWRX
Member#: 166110
2003 Evo VIII
Apex Silver
My oil feed line cracked last night...I ordered all the parts necessary to make a stainless steel oil feed line. This will be much more flexible and less prone to cracking.
elazulWRX is offline   Reply With Quote
Old 08-26-2008, 12:23 AM   #18
onetoenvy
Member#: 167498
04 subi
blue
just to chime back in. i did the stainless steal upgread and it was easy and is much better than the the stock set up and it nice to not have it running under the intake manifold.
Good Luck!!
Wtb oil line off passenger head to the turbo turbotimein253 NWIC Private Classifieds 2 01-25-2010 03:04 PM
Turbo install -- Help, SS Oil Line Leaking?! SonicYeller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-17-2009 08:37 PM
Turbo oil line leak. Hotrod, you have info on the SS line? Tex-WReX Texas Impreza Club Forum -- TXIC 0 05-16-2005 09:28 PM
Turbo oil line leak Robimplicit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-13-2004 12:46 AM
SS lines - leak from hard line after install - help! NotFast Brakes, Steering & Suspension 23 05-06-2003 07:38 PM
