Old 04-27-2008, 07:06 PM   #1
98lgt
Member#: 172692
1994 JDM MR2 Turbo
Default Original T-Belt?
I bought my 1998 Legacy Gt with the 2.5L N/A engine, it had 144k kms and has 150k now. The dealer said the Timing belt needs to be changed every 100k kms. I might be getting paranoid but: Do you think it is possible that i'm on the original belt still? Anyways of checking?
98lgt is offline   Reply With Quote
Old 04-27-2008, 09:02 PM   #2
rkramer
Member#: 118209
2002 WRX Sedan
pull off the cover and see what it looks like, but... i've seen timing belts that appear to be in fairly good condition, except for the clean break.
Old 05-02-2008, 10:27 PM   #3
98lgt
Member#: 172692
1994 JDM MR2 Turbo
My car has 150k KMs. it is recommended according to the Subaru maintenance site that it should be replace at 168k KMs, however should I send it in earlier like now to make sure everything will be okay?
Play the original Super Mario Bros... as the original Mega Man, Samus, Link Christoff Off-Topic 8 05-03-2010 12:13 AM
wtb the two front belt ac belt and crank belt blackstidriver123 Private 'Wanted' Classifieds 2 12-12-2009 05:46 PM
Timing Belt? Drive belt? AzNStiImpreza Service & Maintenance 5 01-18-2004 10:44 PM
Timing belt installation for a PE belt? IA Performance Factory 2.0L Turbo Powertrain 9 10-27-2003 03:45 PM
60 K T belt = timing belt? DoinkMobb Service & Maintenance 10 07-22-2002 01:02 PM
Message Board Statistics All times are GMT -4. The time now is 05:36 PM.
