Old 04-27-2008, 08:32 PM   #1
stevedainee
Member#: 173982
2002 wrx
world rally blue
Default wtf coolant issue
alright here goes....i just replace my rad.; top rad hose; a/c belt and tension...car runs great but i noticed coolant was still needing to be replaced every couple of days...found i was gettin a leak in bottom hose rite where it attachs to engine....so im driving home and about a block from the house stop a a light hear something pop...my temp gauge spikes but quickly drops back down to normal...get home and i can see water on the front bumper rite in the middle....it's dark flashlight has no batteries get under car with lighter and whole under front bumper is wet but i dont see any hoses that arent connected and cant really trace where problems coming from any suggetsions...
stevedainee is offline   Reply With Quote
Old 04-27-2008, 09:16 PM   #2
mikeythejew
Member#: 141672
I would pressure test the cooling system and look for leaks. You used to be able to borrow a pressure tester from autozone which you still may be able to do. If your coolant is low, sometimes you need to add some coolant to help find the leak. You can use water if needed. There are other things but this is the first step I would take. You may see the leak plain as day during daylight hours.
You need to stop smoking btw.
mikeythejew is offline   Reply With Quote
Old 04-28-2008, 06:26 PM   #3
stevedainee
Member#: 173982
2002 wrx
world rally blue
thanks for the feedback i have no idea whuts up i couldn't check it out today had to go to work and...but i took it round the block few times last night everything was normal....weird thing is my lower radiator hose was leakin..but now its not...idk????
Old 04-30-2008, 07:04 PM   #4
stevedainee
Member#: 173982
2002 wrx
world rally blue
found problem...new radiator sux and broke in less than a month...the company said they'll come and replace for free just need to pick up the broke one...so hopefully this ones last more than a f--n month....
Old 05-21-2008, 07:14 PM   #5
schurmo
Member#: 176758
Weird, my went bad after 8 months. Are these replacement radiators that bad?
Schurmo
schurmo is offline   Reply With Quote
Old 05-22-2008, 10:07 AM   #6
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
He doesn't smoke. He's an arsonist! RP
drivin blind is offline   Reply With Quote
Old 05-26-2008, 06:32 PM   #7
Reddstars
Member#: 75804
2002 WRX sedan
Bukakke White wingless!
Just wondering what brand of rad did u buy? I just recently got a new one and had it for less than 2 months and looks like it has a hole or something right in the middle of the rad. Just wondering if it is the same brand?
Matt
Reddstars is offline   Reply With Quote
Coolant issue 1stwrx_inGuam South East Region Forum 8 08-07-2007 10:46 PM
coolant issues rs_two_five Normally Aspirated Powertrain 3 02-16-2007 06:16 PM
Forester coolant issue. Help! BigMikeLV Normally Aspirated Powertrain 6 09-04-2006 09:03 PM
Help: coolant issue?! USF97J4x4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-23-2006 11:53 AM
Coolant issues rhockstra Service & Maintenance 8 12-11-2004 05:55 PM
