Old 04-27-2008, 09:31 PM   #1
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
Default exhaust smokes only after idling for a few minutes and no other times. causes?
I've been basically stage II for a long time. Increased boost, tune, bolt ons. Recently, my car began smoking only after sitting and idling for more than a couple minutes. During/After normal driving, there's no smoke. During/after driving hard, no smoke. Only if I let the car sit and idle for a few minutes will any smoke be visible. Does this symptom point to any particular problem, or could it be a number of things? Thanks for the info...
rex n effect is offline   Reply With Quote
Old 04-28-2008, 07:33 AM   #2
mikeythejew
Member#: 141672
Turbo's can leak fluid with no boost idling and not leak while driving.
I assume you mean after the car has warmed up and it's not valve stem seals puffing right after a cold start? Cracked engine valves can sometimes do this.
Use a mechanics hand held vacuum gauge to help diagnose problems. The boost/vac gauge in cars are usually damped vac side and are of no help.
mikeythejew is offline   Reply With Quote
Old 04-29-2008, 02:37 AM   #3
rex n effect
Member#: 15289
02 wrx pollen silv
yes it's after the car has warmed up...
What will the vacuum gauge tell me?
Thanks.
Old 04-29-2008, 04:30 AM   #4
mattonln
Member#: 163233
02 WRX
Silvy
what color smoke are you getting? if its black then thats an oil issue, which could point to turbo/valve maybe even piston ring issues. if its blueish white then that is coolant and the idle control valve on subarus are known to melt their gaskets, allowing a small amount of coolant to leak into the intake manifold. This would be my guess as you see the smoke while at idle only, meaning when the valve is operating. just my guess tho.
mattonln is offline   Reply With Quote
Old 04-30-2008, 02:54 AM   #5
rex n effect
Member#: 15289
02 wrx pollen silv
it's a really light color smoke. Whatever it is, it's just a slight bit of it. Just enough to allow me not to pass smog...
Isn't coolant flowing through the throttle anyway, if the car is at idle or not?
I thought that if the idle control valve was leaky, that the car would smoke always...
It is worth looking at for sure. Thanks.
Old 05-12-2008, 09:31 PM   #6
dgriff992002
Member#: 158090
2004 Impreza WRX WRB
Hta68 ewg 382 awhp on e85
My car is doing the same thing and I'm also at stage II with bolt on mods but like you it runs fine and the smoke goes away when I drive. but lately it seems that the smoke is there more often. any suggestions? Did you find out anything about yours??
dgriff992002 is offline   Reply With Quote
Old 05-14-2008, 10:37 PM   #7
JDM 3SGTE
Member#: 35479
same issue here. the smoke is definitely white. going to replace the icav gasket tomorrow to see if it fixes the problem. will keep updated.
JDM 3SGTE is offline   Reply With Quote
Old 05-14-2008, 11:11 PM   #8
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
what color smoke are you getting? if its black then thats an oil issue, which could point to turbo/valve maybe even piston ring issues. if its blueish white then that is coolant and...
Just to clarify: Black smoke is fuel, not oil. Bluish to bluish-white smoke is oil, not coolant. White but _not_ bluish is coolant. The rest of the diagnosis I have no comment on.
bulwnkl is offline   Reply With Quote
Old 06-09-2008, 02:53 PM   #9
Mustangdude20
Member#: 176635
02 subaru wrx
psm
any word on this my car is doing this same thing
Mustangdude20 is offline   Reply With Quote
Old 06-09-2008, 02:53 PM   #10
Mustangdude20
Member#: 176635
02 subaru wrx
psm
subscribing
Old 06-10-2008, 05:48 PM   #11
italy wrx
Member#: 36450
2003 WRX
It's the hot side turbo seal.. I just went through the same situation(smokes when idling for a few minutes, then nothing while under boost or driving). I bought a used tdo4 from private for-sale forum and the car hasn't smoked since.. Also, my car started doing this after I went stage 2...
italy wrx is offline   Reply With Quote
Old 06-14-2008, 03:13 PM   #12
jacky599r
Member#: 137631
2006 WRX
Red
dudes, weird. i have smoke at the exhuast too! sometimes it happens during the first crank of the say... else, it puffs whenever i shut her off for a while and start her back up after 10-15 mins or so. I cant say its BLUEISH or not, but certainly whiteish and its just a cloud of smoke and thats it. WHAT HAPPENED???????
P/S: I have a newly built block.
jacky599r is offline   Reply With Quote
Old 06-18-2008, 01:19 PM   #13
tokwc
Member#: 140899
Exactly the same here, with an new hybrid block.
tokwc is offline   Reply With Quote
Old 06-18-2008, 07:04 PM   #14
rex n effect
Member#: 15289
02 wrx pollen silv
so for stock block with no other symptoms, it could very well be turbo seals on their way out?
Old 06-19-2008, 12:46 PM   #15
jacky599r
Member#: 137631
2006 WRX
Red
news?
anyway, hw can i check the integrity of the turbo seal? my 20g is a new piece, less then 3k km clocked....
Old 06-19-2008, 10:12 PM   #16
Uncanny
Member#: 133012
2015 STi
Lightning Red
+1 i get the same thing, Stage II stock turbo, and it has been doing it since i flashed and put on my TBE
Uncanny is offline   Reply With Quote
Old 06-19-2008, 11:45 PM   #17
domdoan
Member#: 182794
Default mine too!
mine too!
domdoan is offline   Reply With Quote
Old 06-20-2008, 06:43 PM   #18
kenyaboy
Member#: 68056
2005 WRX
BLACK
i have the exact same problem at idle after a fea minutes the car smokes blue/whiteish smoke that smells of oil ,checked the downpipe today and found burnt on oil residue or so it seems,
also the exhaust has what looks like soot all over it
hardly any oil in the throttle body but there was some
put the catted oem dp back on and now no smoke?and no oli smell?
Im pulling the plugs tomorrow,,,,,,,
kenyaboy is offline   Reply With Quote
Old 06-20-2008, 06:44 PM   #19
kenyaboy
Member#: 68056
2005 WRX
BLACK
oh car is flashed with catless dp and a cat back
Old 06-21-2008, 10:45 AM   #20
jacky599r
Member#: 137631
2006 WRX
Red
i pulled on of the intercooler pipe and it was dry dry dry...
still smokes like hell on starts...man somebody needs to get to the root of the prob
Old 06-22-2008, 08:40 PM   #21
Pat L.I.
Member#: 20498
2006 WRX TR
Just Chiming in to subscribe, my 06 does this only the first time i hit the gas after the car has been idling for a while. does not do it from stoplight to stoplight or while idling.
Pat L.I. is offline   Reply With Quote
Old 06-22-2008, 09:04 PM   #22
dgriff992002
Member#: 158090
Did anybody ever get to the bottom of this? I took my car in to have it looked at and they told me that it was normal This was about a month ago. The car seems to be doing it more and more lately I guess if I have to I'll drive it till it blows then take it in and tell them I told you so but I don't wanna do that I'd rather fix it and hopefully soon.
Old 06-23-2008, 07:50 AM   #23
jacky599r
Member#: 137631
2006 WRX
Red
strangely, i managed to pull it off after 5 mins of idling and step on the throttle and i can see some white smoke....geeeeeeeeeeee............................ .............
Old 06-24-2008, 12:40 AM   #24
Wagowned
Member#: 133689
2004 WRX Wagon
I have a stage II with a VF39 that does this and it's been more frequent as of late. At first it would only smoke a little occasionally while sitting at idle for 5-10min. Now it does it at every other red light when I sit for a minute or two and it's considerably more smoke (blue-ish white, definitely oil). I assumed (hoped) that it was turbo seals because my wallet would rather get the turbo rebuilt then replace some piston rings. =)
Wagowned is offline   Reply With Quote
Old 06-24-2008, 05:53 AM   #25
jacky599r
Member#: 137631
2006 WRX
Red
im just wondering how can e check if its the turbo seal? or valve stem seal or what not?
i just had my motor built and it happened only after that
04 STI Smokes After Idle For A Few Minutes, HELP! thenewrick Newbies & FAQs 36 04-26-2010 11:26 PM
Car heats up after idling for a long time. burritotown Newbies & FAQs 22 01-15-2007 03:18 AM
Morning brake clunk / sounds scuffy for a few minutes normal on STi? overdose Brakes, Steering & Suspension 4 01-03-2006 01:39 PM
STi w/ only Helix Catted DP and no other mods on stock ECU tune SirWilliam Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-17-2005 02:30 PM
Does your WRX drive funny for a few minutes or so after a launch? WRXakaBooSTi Transmission (AT/MT) & Driveline 11 01-25-2005 09:33 AM
