Old 04-27-2008, 09:46 PM   #1
acracing21
Member#: 168022
2004 Wingless WRX
San Remo Red
Default optima redtop install
i just installed my optima red top from one car to my WRX. beacause of the reverse polarity i had to mount the battery backwards so that the connectors were facing backwards. now they are on the back side of the battery and have been fully connected that way and everything works out.
i have one question though, has anyone else had to do this??? the redtop is sealed and claims it wont leak. but should i rely on this and keep it mounted this way.
another question is, to change the connectors to the connectors on the side of the battery that is now facing up. what parts do i need?
acracing21 is offline   Reply With Quote
Old 04-27-2008, 09:55 PM   #2
03 wrb
Member#: 102465
03 wrx
wrb
You bought the wrong one, i did the same thing but luckily i changed it in the advance auto parking lot...so I walked back in and bought the right one.
03 wrb is offline   Reply With Quote
Old 04-27-2008, 10:17 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yup you got the universal one (35/75 instead of 35). Best option is to return it and get the correct 35, unfortunately those are usually not available in stores (check Advance Auto, they may have it) and have to be purchased online.
If you are stuck with the universal, the only proper way to install it is to replace the starter cable with a longer one. Search for posts with keyword "Optima" and my username for more info, look for the posts that are several years old.
Old 04-27-2008, 10:51 PM   #4
acracing21
Member#: 168022
2004 Wingless WRX
San Remo Red
yeah i actuallly just took this battery out of my chevelle and put it into my wrx. will this do the trick for the time being until tomorrow when i can but the new battery??
Old 04-29-2008, 09:30 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you should be just fine until you get the new battery - the optima will work in any orientation.
Old 04-30-2008, 12:34 AM   #6
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
I have the 35/75 in mine. I just put a longer starter cable on the car. As far as you being worried about it leaking or anything, don't worry. I used to work at Advance Auto Parts. I have seen two of those things all but destroyed and they didn't leak. A guy I worked with had one in his Nova. His tie down broke and the battery fell on his header. It melted half of one cell off and it still worked fine and there was no liquid leaking from it.
Ryan
FourOnTheFloor65 is offline   Reply With Quote
Old 04-30-2008, 06:14 PM   #7
subaru3169
Member#: 55252
* pullup bar *
i have the universal yellowtop.. i had to use a metal extended plate thingamabobber for the positive.. got a good deal, why not
subaru3169 is offline   Reply With Quote
optima battery install, thread 3,569. install help stil2stock Electrical & Lighting 4 11-06-2006 06:05 PM
optima redtop civichunter2 Electrical & Lighting 2 03-20-2006 10:31 PM
Optima Redtop fitment ... not quite optimal? Necromancer Vancouver Impreza Club Forum -- VIC 7 11-19-2005 03:15 AM
fs: Barely used optima redtop lotusdrift Mid Atlantic Impreza Club -- MAIC 6 11-14-2005 07:31 PM
Optima Yellow Top 51R Install trouble pigeonfarmboy Electrical & Lighting 5 05-21-2004 11:32 AM
