Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 04-27-2008, 11:38 PM   #1
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
Default Should I do headlight relay/ground upgrade/mod before I upgrade to HID ??
I'm going to pick up some HID headlights in the near future.
Should I bother doing the headlight ground upgrade, as well as upgrade with relays and much thicker wiring ?
will this make a difference even with the hids ?
IllNastyImpreza is offline   Reply With Quote
Old 04-28-2008, 04:42 AM   #2
PA-Outback2000
Member#: 161832
2000 Outback Limited
check xenonexpert.com for apexcone HID conversion. they have a relay kit if u really want to put it in. i just bought the kit and it plugs right into the stock wiring harness. i have had them in since november with no probs. i would definitely racommend this set.
PA-Outback2000 is offline   Reply With Quote
Old 04-28-2008, 01:29 PM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
hid kits themselves are not recommended, but if you do end up getting one, yes, you will need some sort of relay harness.
hid ballasts draw a higher amp rate at startup, which can be too much for factory wiring.
jdubya301 is offline   Reply With Quote
Old 04-28-2008, 02:13 PM   #4
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
ok good to know.
I will definatly upgrade my headlight wiring then.
is there a decent write up somewhere of how to upgrade them with relays?
Old 04-28-2008, 03:42 PM   #5
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
i havent seen a write up before, but i can sure help u do it.
i am just not familiar with the electrical system of a 98, but if you let me know what type of connectors/bulbs it uses, i will help you wire everything up.
Planning on going to the dyno to tune....What should I do before I get there? SurfWagon Engine Management & Tuning 7 01-23-2010 01:31 PM
What mods should I do before I get a cobb accessport v2? pfinch117 Newbies & FAQs 13 10-17-2009 11:31 AM
anyone planning to do the A/C Microswitch mod? want your car to be famous? alacrity024 New England Impreza Club Forum -- NESIC 37 02-13-2007 08:39 PM
What should I do next as far as mods? shaneconaway Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-09-2006 11:22 PM
Anyone make an upgraded headlight relay harness compatible with DRL's? Daz Electrical & Lighting 6 11-21-2004 01:13 PM
