Old 04-28-2008, 04:21 PM   #1
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default impact wrench
i just got a new impact wrench so i can start suspension work. never had a fancy inpact gun allways handtools.
i feel retarted but whats the trick to getting the socket on the gun?? it doesnt seem to go on.
i purchased a craftsman 1/2'' 400ft/lb and a set of metric deep socket 1/2'' ers.
do i need to hammer them on or something?
watchunglava is offline   Reply With Quote
Old 04-28-2008, 04:30 PM   #2
rougeben83
Member#: 115154
2003 Legacy L Turbo
the locking pin can be pretty stiff, especially on a new gun, get a flat head and depress it while you press the socket in, it should slip easily...taking it off can be just as hard sometimes too...
rougeben83 is offline   Reply With Quote
Old 04-28-2008, 04:37 PM   #3
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
NA Forum... ugh
EvoSpeed is offline   Reply With Quote
Old 04-28-2008, 05:33 PM   #4
96SubyImpreza
Member#: 157692
2004 Widebody WRX
Ferrari Corsa Red
wrong forum.. your impact gun is in fact not naturally aspirated.. learn how to read dont be illiterate....
push the damn thing on its not that complicated.
96SubyImpreza is offline   Reply With Quote
Old 04-28-2008, 05:33 PM   #5
96SubyImpreza
Member#: 157692
2004 Widebody WRX
Ferrari Corsa Red
better yet yea just hit it with a hammer.. then learn to read.
Old 04-28-2008, 06:09 PM   #6
kevinblahh
Member#: 158319
2005 STi
rough crowd
kevinblahh is offline   Reply With Quote
Old 04-28-2008, 06:14 PM   #7
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Many of them have the pin that is square edged rather than spherical to prevent tools from getting off accidentally and hit someone. In this case, you will need a small screw driver or such to push the pin in when putting on and when taking off sockets.
Hope this helps.
jerry
Jerry Xu is offline   Reply With Quote
Old 04-28-2008, 07:41 PM   #8
piker28
Member#: 22664
wow, sand in your vagina much? guy was just asking a question you do not have to treat him like hes mentally handicapped
piker28 is offline   Reply With Quote
Old 04-28-2008, 09:35 PM   #9
96SubyImpreza
Member#: 157692
2004 Widebody WRX
Ferrari Corsa Red
i'm sorry but it seems like more and more people just dont seem to understand the idea of a forum based on a single subject and insist on plaguing it with matter completely irrelevant to the subject header.
Old 04-28-2008, 10:08 PM   #10
piker28
Member#: 22664
ok so do you think its wiser instead of speaking normally to a person and showing them what they did wrong is not as effective as just screaming at them?
has this poster done this before? no, so than he did not really know better dont rag on the poor dude, im sure when you first joined you made stupid threads in wrong spots like the rest of us
Old 04-28-2008, 10:19 PM   #11
Skidd
Member#: 1853
GC6 Supercharged
STM
Woh... seriously guys! lighten up already! A minor error. We're human, we make mistakes. It's not the end of the world. Sheesh! Now that your done flexing your internet muscles, ask your self if what you have written contributed to this forum, or not.
And to help the OP. (wrong forum or not). I don't own one, but the impact gun my Dad has requires pressing a button to both release and attach sockets to it. Perhaps your model has a similar feature?
Skidd is offline   Reply With Quote
Old 04-28-2008, 10:33 PM   #12
96SubyImpreza
Member#: 157692
2004 Widebody WRX
Ferrari Corsa Red
my apologies. week full of distress.
Old 04-28-2008, 10:38 PM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
I use a worn out grinding stone from a Dremel or any other 1/8" shaft I can pick up handily. It should loosen up over time....but it's a PIA when you tug and tug to change sockets.
Jay Storm
Old 04-29-2008, 09:53 AM   #14
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
impacts have 2 main types of retainers to hold sockits in place
most usual is the sliding ball type, where the ball depresses as socket slides on, then fits into a detent in the socket. this type can be a real PITA to use, you often have to use a nail or other thin implement to push the ball down to get the effin socket on/off. lube it liberally to help.
other type is a circlip at end of impact gun shaft, this type tends to loosen up after a bit of use. meanwhile, be sure the socket shape lines up precisely with the shaft, then push socket down onto floor to engage it. to get it off, use dynamite
or a screwdriver to pry it off
main thing with an impact is THREAD FASTENERS ON BY HAND BEFORE TIGHTENING, unless you like to have nuts cross-threaded. and one more thing...impact gun is NOT A TORQUE WRENCH.
RB5 Clone is offline   Reply With Quote
Old 04-29-2008, 10:01 AM   #15
J. Steinbeck
Member#: 140575
2005 Legacy GT sedan
Affirmative on what others have said... you just have to use force, lube and a screwdriver can help, and it will probably loosen over time.
Look at the bright side, though. I'd rather deal with one that fits too tightly than one that snaps onto attachments so loosely that it has a tendency to sling swivel attachments at my head when I'm trying to undo bell housing bolts at three in the morning, in turn leading to blood loss and long strings of cuss words. *breath*
I'm not speaking from experience or anything.
J. Steinbeck is offline   Reply With Quote
Old 04-29-2008, 12:19 PM   #16
rkramer
Member#: 118209
2002 WRX Sedan
I agree... If you look at the mechanics of an impact gun it is very plain to see it is forced induction. they tend to work best at 80-100 psi in fact. certainly not N/A.
Impact Wrench and Impact Socket Set Andrew Non-Subaru Stuff 3 07-13-2007 06:13 PM
Impact wrench OK with locking security lug nuts? megatron Brakes, Steering & Suspension 5 03-11-2002 06:56 PM
Opinions on electric impact wrenches? gtguy General Community 22 01-28-2002 05:09 PM
Gonna buy the 12vdc impact wrench RidinLow General Forum Archive 4 11-27-2000 12:55 AM
12 VDC impact wrenches - any good? Mike Smith General Forum Archive 9 11-22-2000 08:40 AM
Message Board Statistics All times are GMT -4. The time now is 04:13 AM.
