Old 04-28-2008, 05:58 PM   #1
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
Unhappy Headlight Problems... Any Suggestions?!
The headlight on my 05 rs seems to be out
it is not the actual headlight itself but one of the round driving lights on the corner of the headlight
a friend who took a look it the light believe it is only a disconnection problem
but if it is (will end up replacing bulb anyway).. How do i replace that bulb?
will i need to remove headlight? or is it easily accesible?
if so what bulb can i use? a non-amber colored bulb possible?
thanks heres a picture pointing out wat im talkin bout wit the location of bulb
CoBB_tHiS! is offline   Reply With Quote
Old 04-28-2008, 08:20 PM   #2
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
anyone at least know the name of them so i can do some searching?!
Old 04-28-2008, 09:31 PM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
do you have a owners manual? it would be clearly stated in there.
jdubya301 is offline   Reply With Quote
Old 04-28-2008, 10:30 PM   #4
LightWerkz
Member#: 125432
2004 E46 M3
http://lightwerkz.net
clear 194/168 bulb is what you need, any auto parts store should have it and yes you need to remove the light, which oly takes a minute or two.
LightWerkz is offline   Reply With Quote
Old 04-29-2008, 11:43 AM   #5
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
alrite sounds good thanks
do i need to open up the light fixture?!
theres no legal rules with those bulbs right?
Old 04-29-2008, 12:04 PM   #6
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
it's gotta be amber...unless there's a yellow shield over it...then it'll come out amber anyway ;-)
you don't need to open up the fixture. should be just a plug in the rear.
Tahoe SC is offline   Reply With Quote
Old 04-29-2008, 07:38 PM   #7
CoBB_tHiS!
Member#: 171730
2013 WRX Limited
shyttt.. does it really?!
damn that blows w/e
Old 05-02-2008, 12:07 PM   #8
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
its the parking light. mine likes to go out randomly, all i do is give it a good smack and the light comes back on. you have to remove the whole headlight assembly to get to that one bulb. i have yet to figure out how to get it out, even with instructions from the owners manual... im 99% certain i removed all the bolts, etc, and it still wont come loose. the outside edge doesnt want to budge, and im afraid of breaking something.
hope you have better luck that i do.
nkx is offline   Reply With Quote
Old 05-02-2008, 12:31 PM   #9
-Kevlar-
Member#: 82378
its probably a snap or two youre missing... just tug it a bit.
-Kevlar- is offline   Reply With Quote
Old 05-02-2008, 01:59 PM   #10
steverx05
Member#: 128269
Guys, you twist the parking light counter-clockwise to get it out.
steverx05 is offline   Reply With Quote
Old 05-02-2008, 02:59 PM   #11
Handsdown
Member#: 29355
yeah tugging it will break the wires or plastic housing/holder.
Handsdown is offline   Reply With Quote
Old 05-02-2008, 03:15 PM   #12
-Kevlar-
Member#: 82378
are we talking while the headlight is still in or out? i thought he couldnt get the headlight out to access it.
Old 05-02-2008, 05:29 PM   #13
steverx05
Member#: 128269
You have to take the whole light off the car to get to the parking light bulb.
Old 05-02-2008, 05:34 PM   #14
Handsdown
Member#: 29355
i guess we're talking about getting the headlight out... there's a plastic plug with a metal thing and a bunch of screws, it's probably either not clearing some metal piece or the metal plug is still in.
Old 05-02-2008, 07:40 PM   #15
-Kevlar-
Member#: 82378
i was saying tug on the headlight to get it out thinking he couldnt get the whole assembly out. the plug on the back, although im not familiar with it, im sure you have to twist then pull....
Old 05-02-2008, 07:59 PM   #16
Handsdown
Member#: 29355
tugging won't help if it's not clearing a metal brace or if the screws aren't out or if the tugging is in the wrong direction, it should be straight forward away from the rear of the car. i think we're all on the same page here just getting confused because of words.
Ant problem, any suggestions? xothermic Off-Topic 16 06-22-2005 11:18 AM
ECU problems, any suggestion?? ezaldere Electrical & Lighting 0 07-08-2004 07:47 PM
ECU problems, any suggestion ezaldere Service & Maintenance 8 06-30-2004 10:08 PM
O2 senser problem...any suggestions? Subi01 Service & Maintenance 1 01-26-2004 07:55 AM
Door light problem.. any suggestions? Herojin Electrical & Lighting 3 05-23-2003 05:19 PM
