View Poll Results: Factory rev limiters?
Ignition cut 11 50.00%
Fuel cut 11 50.00%
Voters: 22. You may not vote on this poll
Old 04-29-2008, 12:44 AM   #1
rice h8r
Member#: 94524
Question Factory rev limiter, ignition cut or fuel cut?
I always thought that stock rev limiters cut the fuel pump, but my friend says that even on factory systems it cuts the ignition.
http://en.wikipedia.org/wiki/Rev_limiter
which one is it?
rice h8r is offline   Reply With Quote
Old 04-29-2008, 12:50 AM   #2
Ozzman
Member#: 18879
95 Civic
green
I know my honda shuts off the injectors to induce the rev limit. I'm pretty sure the stock subaru rev-limiter uses the same method.
Ozzman is offline   Reply With Quote
Old 04-29-2008, 12:54 AM   #3
Protege Menace
Member#: 41950
faq u rug
why would it cut the fuel pump what exactly would that accomplish?
either its injectors (herro lean) or spark cut 9which I'm going to hope most vehicles are nowdays)
Protege Menace is offline   Reply With Quote
Old 04-29-2008, 12:56 AM   #4
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I would bet ignition cut, it may be kind of unsafe to cut fuel under boost. ???
Then again the ecu could cut fuel and ignition at the same time...
2slofouru is offline   Reply With Quote
Old 04-29-2008, 12:57 AM   #5
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
I know S2k's cut fuel(at the injector I assume).
Dolphin Overton is offline   Reply With Quote
Old 04-29-2008, 09:18 AM   #6
Chuck H
Member#: 20442
Pretty sure that most factory rev limiters, including turbo Subies are fuel cut. That's why you don't want to sit there bouncing off the rev limiter like you can with an ignition cut aftermarket launch control.
Chuck H is offline   Reply With Quote
Old 04-29-2008, 09:36 AM   #7
jays05
Member#: 78165
05 STI 35r + e85
We get fuel cut and eventually it closes the throttle body.
jays05 is offline   Reply With Quote
Old 04-29-2008, 09:44 AM   #8
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
I'm pretty sure it just applies the brakes--just like traction control.
Asinine is offline   Reply With Quote
Old 04-29-2008, 09:45 AM   #9
waktasz
Member#: 86356
2015 s1000r
wheelie monster
If it only cut ignition and not fuel, where would all that gas go?
waktasz is offline   Reply With Quote
Old 04-29-2008, 09:48 AM   #10
Asinine
Member#: 55173
with paddles.
It stays in the cylinder until the next spark, and then you get a TON of power. That's the whole reason to bounce off the rev limiter when launching.
Old 04-29-2008, 09:59 AM   #11
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Old 04-29-2008, 10:02 AM   #12
hikeeba
Member#: 89165
Poop Stuck Survivor
-=C=- & subari87 FOREVER!
More specifically, the cylinder piston brake are activated at about 250 rpm beyond redline. The brakes slow the pistons down, the same way they do with traction control.
hikeeba is offline   Reply With Quote
Old 04-29-2008, 10:16 AM   #13
Samuelleeogden
Member#: 66066
04 STi
black on sold
if it was ignition cut, stage 2 ers would sound like they had Bee*R rev limiters at the rev limit.
Samuelleeogden is offline   Reply With Quote
Old 04-29-2008, 10:26 AM   #14
vapore0n
Member#: 21356
2010 BMW 335i
2017 STI Limited LBP
reality is it gets sent back to the gas tank
vapore0n is offline   Reply With Quote
Old 04-29-2008, 04:44 PM   #15
rice h8r
Member#: 94524
Not all cars have a return line. Doesn't it just spray into the cylinder, hence the crazy after firing on cars with aftermarket ignition cut rev limiters?
Old 04-29-2008, 04:54 PM   #16
02wrbrex
Member#: 103061
98 Impreza EJ207
FJC
SRT-4s have a spark cut. Fuel still build ups then shoots flames while bouncing off of the rev limiter as the spark fires again.
02wrbrex is offline   Reply With Quote
Old 04-29-2008, 04:59 PM   #17
Lamb155716
Member#: 155716
2008 Spesh Pitch Pro
2010 Spesh Roubaix Elite
hahha
im pretty sure a lot of the unburnt mixture goes out the exhaust valve and eventually ignites in, or prior to the turbine (due to enormous heat) thereby inducing spool. that's why you do it at launch or coming out of a corner. As anti-lag srategy
Lamb155716 is offline   Reply With Quote
Old 04-29-2008, 09:01 PM   #18
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Funny how many posters are saying fuel cut, but by vote ignition cut is winning 2 to 1 so far...
Old 04-29-2008, 09:59 PM   #19
Ozzman
Member#: 18879
95 Civic
green
I'm pretty sure the reason most manufacturers use fuel cut revlimiters is for emissions purposes and to make sure you don't blow out a cat when it gets soaked in fuel bouncing off an ignition cut, then when you finally get out of the limiter all that fuel ignites in the cat thus severly shortening its lifespan if done repeatedly.
Using a fuel cut for the revlimiter prevents this problem. Bouncing off the fuel cut ocasionally and for a breif second or two won't hurt the pistons.
Old 04-29-2008, 10:04 PM   #20
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
What about detonation?
Rev-limiter kills injectors or pump? bg9 Normally Aspirated Powertrain 4 04-23-2007 06:38 PM
Rev limiter: Fuel cut or spark cut? Marion Cobretti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-25-2005 04:35 PM
Boost creep or fuel cut? Other? jaysp55 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-29-2004 03:56 PM
Launch control - ign or fuel cut? Houdini Engine Management & Tuning 15 07-09-2004 12:20 PM
Factory rev limiter john banks Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-24-2003 03:36 PM
